No details given as to to make and model, so we GUESS!!
The F0 error code indicates a Failed Thermistor Control. Resolution: The following is the procedure to clear the circuits for the F0 error code: Power off the unit, wait 5 minutes then restore the power. ... Down" and "Minute Down" keys simultaneously for 3 seconds, then the time of day will be displayed.Jan 25, 2010
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
F0
Stuck touch pad
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
F0 - F1 - F7
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by: 1. Pushing CLEAR/OFF pad. 2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
