Question about Maytag Dependable Care LAT9706
Servis washing machine
Hi there can any one help.... my washing machine won't work the red on light comes on but the cycle on any setting won't start...but if you turn the washing machine on/off button off the door timer still kicks in. so i belive it must be somthing to do with the cycle bit. If anyone can help i would be most greatful.
  • PaulT1 Jan 04, 2008
    I have a Maytag Model 9806AGE with a similair problem to the one described by littlelegz's post. I had some history with the lid switch not stopping the washing machine from starting when the lid was up. Now the machine fails to start on any cycle although all the lights are on.
    I have tried turning power OFF-ON and changing settings & cycles to start on but it doesn't start on any of them.
    How can I prove the problem is with the lid switch?
    President:
  • 878 Answers
There was a service bullitin on this model concerning the lid switch and this sounds like your problem. Maytag redesigned it because of excessive failures. The new switch kit part number is 12001908. I don't know if you would have any luck contacting Maytag with regards to repairing this for free, but you could check. For reference the bullitin they put out was TCL-0001-b. If you cannot get anywhere with them, it's not a hard fix. We should be able to walk you through it. Catriver..post back
Posted on Aug 03, 2006
Hi my Servis M4905 Dishwasher has stopped working properly, when you set the programme and close the door it seems to start its cycle but after a few minutes it stops all the lights come on except the...
Hi it may be that the heating element has a fault in other words short circuit, you will need an electrician or a service engineer to check that, as the water fills into the washer it then tries to heat the water first to carry out further duties in the cycle. I hope that this message might help you eric
Nov 14, 2017 | Servis Dishwashers
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
Washing machine won't go thru spin cycle. Lid lock light flashed some at first, now won't come on at all.
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Jul 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Switches on but wont start cycle
i got the same problem..i get a flashing light after i turn it on.was told you have to put to reset at end of cycle then turn off..
i dun it..it dont work.
i just play around wiv the buttons till it goes..
Jul 14, 2009 | Washing Machines
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
Washing machine not working
I Put A Set Of New Brushes In motor And It started
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Washing Machines
Washing Machines Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
