Question about General Garden
Gmc pressure washer 1400 manual
Manual for how to use
I need to know where to put detergent in the pressure washer I have no model number
These units come with a detergent bottle that attaches to the spray wand. The manual describes what detergents to use and the attachment reduces the pressure and siphons the right amount of detergent from the container. It is not a good idea to try to run detergent through the pump.
Here is a link to the operating manual for a similar pressure washer.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/pw0501400.pdf.
Mar 05, 2015 | Coleman Powermate DuraBuilt 1400 PSI...
Need to download manuel for fh140a 1400 PS! pressure washer 113GPM Electric Pressure washer
You may download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jun 18, 2012 | McCulloch FH140A Electric Pressure Washer
Need the manual
A model number would have been helpful; however this may be your manual:
http://www.powermate.com/pdfs/2007/11/10/manual_pw0501400.pdf
If the above is not your manual, check your unit for a model number and then review or search the list here:
http://www.powermate.com/productmanuals.php?cat_id=6
Jun 28, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
My Durabuilt DB1303 pressure washer leaked oil. I
30 weight oil is what i use. Im assuming the oil plug does not have a little plastic dipstick. Place on level surface fill until just below thread line about 1/4" below the threads. I hope this has helped if i can help further let me know. Please rate how helpful this answer was. Good Luck and have a great weekend. Jeff
Apr 04, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
WATER LEAKS FROM INSIDE THE 1400 PRESSURE WASHER
Replacing Compasster, where on the terminal block does the black and white wires go?
Mar 08, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Garden Logo
198 people viewed this question
Top General Garden Experts
dennys23601
Brett Duxbury
Brett Duxbury
Are you a General Garden Expert? Answer questions, earn points and help others
