My toshiba Satelite A200 is hang when AC adaptor is insert
Laptop is runing normaly in bettery power. but it is freez when adptor is insert
  • 734 Answers
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Posted on Feb 08, 2012
2 Suggested Answers
byteguy
  • 2229 Answers
SOURCE: Toshiba A200 1vo. works on
You say you bought a new adapter--was is a Toshiba adapter? Was it a "generic" one?
You have to be careful, because some adapters have different polarity and could damage the computer.
If you are sure the adapter is OK and is putting out the correct voltage (~18 v.) then disconnect the battery and try running the computer without the battery just using the adapter.
I don't think this is a BIOS problem. The operating system should not affect the function of the adapter.Most likely you have a motherboard problem if all else is working.
Posted on May 31, 2011
Toshiba A200 1vo. works on battery but freezes when ac adaptor is inserted then has to be turned off manually-no keys function at all except on/off button.Won't start upon ac adaptor either although...
May 31, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My computer do not turn on at all.. i got new bettery and got new ac adptor charger.. stil it wont turn on... when i plug the charger it shows the blue light .. but when i trun on the power button it turns...
Take your battery out and stick it back in... make sure it is locked and fitted in there properly.... nothing wrong with the hard drive or virus... maybe you have the wrong battery... or AC adaptor... hope this helps :)
Jan 09, 2011 | HP 435768-001 - Compaq Presario C300...
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
My Laptop Will not sleep on AC Charge
Try using Power Options in the Control Panel. Define exactly how you want laptop to behave with either battery or AC.
May 23, 2009 | Toshiba Satellite A60-S1561 Notebook
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
