JVC DR-MV1S DVD Recorder / VCR Combo
Problem for JVC DR-MV1S DVD Recorder / VCR Combo
Constantly Loading
By poshDi on Aug 02, 2006
My DVD/Video combi is just out of warranty, (purchased 06/06/2005).
I noticed it flashing Loading without a DVD insitu. When I try to open the DVD drawer nothing happens so I cant load a DVD to check whether it is a laser or dust problem. The video works fine!
I emailed JVC and got the following reply:
This symptom is due to a malfunction of the unit and our technical support dept are aware of this and has the hardware upgrade for it. As after sales service(12 months warranty) operates through the dealer, we would recommend you contact your dealer from whom the purchased was made.
They will arrange service under the terms of the guarantee.
Your dealer will be aware of our technical support service, who will offer every assistance to ensure that an effective repair is made.
I bought the unit from a website and because the warranty is up no-one seems interested, even though JVC are aware of the problem! Any ideas or advice would be greatly appreciated.
Comments:
Aug 15, 2006
- Thanks Deb
I'm in the UK and have spoken to several people who's JVC DVDs have started playing up! Perhaps there is a common fault which JVC are not admitting to? Keep in touch
Di
Same Problem
Dec 12, 2008
-   I have same problem with Sony RDR-GX330.
IT IS STUCK ON "WELCOME ".-   afamili
Jul 16, 2008
-   I was watching a DVD when it started flashing loading even though the movie was only playing a couple of minutes it use to work now all it does is flash loading -   Guest
Dec 10, 2007
-   Whether I unplug and let set or what ever it constatly shows loading and unable to open the DVD tray or operate any system.-   Snake Doctor
Best Solution
posted on Sep 06, 2006
Very Helpful)
The Hammer
Rank: Apprentice
Rating: 100%, 5 votes
the... indicated that his solution for
RDR-GX315 DVD... Problem
is valid for all JVC DVD Players
a new DVD disc hangs in "load" or gets stuck in "format" or "finalize" modes seems a very common problem with Sony's recorders. First pull the power plug, then swing down the DVD tray door, there's a little gear on the lower left that can be carefully turned to eject the disc. This has happened to me several times since i got this recorder in January. Obviously a control logic bug.
Was this helpful?
Yes
No
Solution #2
posted on Nov 15, 2006
Very Helpful)
mr_mahoney
Rank: Apprentice
Rating: 100%, 1 votes
Just called JVC tech support. They admit problem and will repair for free (just ship it to them) 11-15-06
Was this helpful?
Yes
No
Solution #3
posted on Aug 15, 2006
Helpful)
Deb1082
Rank: Apprentice
Rating: 90%, 1 votes
I have done additional research and found several sites that list this problem. This sound like a lemon problem and there may be lemon laws in your state. I live in California and will be checking into it. Wish us luck!
Was this helpful?
Yes
No
Solution #4
posted on Aug 03, 2006
Somewhat Helpful)
take
Rank: Wiz
Rating: 79%, 491 votes
everything in repair is money, all depends in cost, you paid for what you get and you get what you pay for..if it cost you a lot you repair it but if was cheap dont waist you time.. I can tell you send it to JVC they will help you but how much you gona paid for it (shiping insurance and time) better check for a local tech may be is cheaper...good luck
Was this helpful?
Yes
No
Solution #5
posted on Feb 13, 2007
Somewhat Helpful)
just
Rank: Guide
Rating: 92%, 4 votes
replace spindle motor and lazer
Was this helpful?
Yes
No
Solution #6
posted on Sep 25, 2006
Somewhat Helpful)
MrSqueezles
Rank: Apprentice
Rating: 75%, 1 votes
I had a similar problem. Try holding down the stop and eject buttons for 3 to 15 seconds. If that doesn't work, try stop, eject and play.
Was this helpful?
Yes
No
Solution #7
posted on Aug 24, 2007
Not Rated)
camilion4
Rank: Apprentice
Rating: 0%, 0 votes
I just fixed my player by removing the top cleaning the lens and spinning the gears that should be in veiws gives it a jump start and now plays fine. Hope this helps.
Was this helpful?
Yes
No
Solution #8
posted on Feb 02, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
password problem
Popular Solutions for JVC DR-MV1S DVD Recorder / VCR
Questions and Unsolved Problems for JVC DR-MV1S DVD Recorder / VCR
Do you recommend JVC DR-MV1S DVD Recorder / VCR Combo?
Answer
Answer
It keeps switching itself off! I have to switch it off at the mains, then on again. It comes on for... (More)
Answer
DVD side will not record but, it will play dvd's.
Answer
i have a hd tv & hd tv outside antenna, will i be able to record digital stations with this... (More)
Answer
Loading light keeps flashing - On/Off switch is malfunctioning - Door to DVD will not open
Answer
I have a JVC DR-MV1S. The power was off. During the night it began to flash "Loading".... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JVC DR-MV1S DVD Recorder / VCR...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
