Error message on pioneer pdr 609 says din unlock. How is it cleared ?
SOURCE: have purchased a PDR - 609 AND NEED THE OPERATING MANUAL
downloaded a copy
Posted on Apr 11, 2009
kevbuzz
SOURCE: hi can i record on my pioneer pdr 609 cd without
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Posted on Jul 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have PIONEER PDR 609 C.D RECORDER AND I HAVE
Not a very specific problem description...
Did it ever work for you? You don't say what DOES happen when you try.
Is the signal reaching the recorder? Is it visible on the display when you select MONITOR?
Are you using CD-R AUDIO or MUSIC blank media? It requires them, not CD-R data disks.
Tape Input should be straightforward if you don't want to route it through a receiver - L and R Out from the deck to L and R Input on the CDR.
Through a receiver: if it has capacity for two decks, connect the PDR-609 itself as a the second cassette deck, then select copy, duplicate or whatever passes for it on the receiver to copy cassettes.
Without specifics of your interconnected gear I can't really go much further.
Phono is a whole 'nuther thing. Traditional turntables require a phono preamp (generally present in old receivers) to boost the tiny signal generated by the stylus to a usable level for downstream electronics. Most modern AV receivers DO NOT have a phono preamp.
Posted on Jan 31, 2010
SOURCE: CHECK message on Pioneer PDR-555RW display
have a Pioneer PDR-555RW with blinking CHECK message on display after repeatedly open/close operation. I cleaned ... - posted in CD Players
Posted on Apr 29, 2011
dunnbiker
  • 8546 Answers
SOURCE: Getting error message "Din Unlock
That means you don't have a good DIgital INput (get it?) signal or bitstream. Correct the source's playback or connection.
It's on page 37 of the manual.
Posted on May 03, 2011
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
May 03, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Jul 17, 2010 | Pioneer PD-R555RW CD Recorder
How do you finalize after recording a cd?
What model?
My Pioneer PDR-609 requires pressing the Finalize button; then after it displays the time it would take to finalize it I press Pause and it counts down.
Feb 03, 2010 | Audio Players & Recorders
Jan 31, 2010 | Audio Players & Recorders
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
51 people viewed this question
 Grubhead
Grubhead
