Question about Samsung Televison & Video
Samsung 46 inch lcd no picture only sound
My samsung 46 inch tv was working fine. The picture is not showing anymore, the sound is coming. I tried switching it off and tried to change the source but nothing comes up on the screen
  • Samsung Master
  • 8,617 Answers
Could be backlight or the Invertor. While the sound is operating shine a flashlight into the screen and see if you can see the picture or not then let me know and I will assist you. But I will also need the model number of the set.
Posted on Feb 08, 2012
  • 113 Answers
SOURCE: lns4692d no picture
No it is the little board underneath the metal container at the top middle of the panel..the very top.
-Josh
Posted on Mar 14, 2008
  • 191 Answers
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
for bn94-00963b go and change your backlight inverter
Posted on Oct 05, 2008
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
How do i fix volume problem , i have samsung 46 inch lcd , picture working fine but no sound?
Hi is your television running through a foxtel box or something else that has volume control, If so you might have one or the other turned all the way down, turn both volumes up and control every thing through one remote control.....
Mar 15, 2016 | Samsung LN46B550 46 in. LCD HDTV
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Television turns on and off automatic (or reset) 4 or 5 times before picture comes on, when first turning it on.
What you describe is an indication of a failing power supply. It tries to start but fails, then repeats startup.
Oct 28, 2014 | Samsung LN46A630 46-Inch 1080p 120Hz LCD...
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
Mar 02, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung LCD 46 inch half of the screen is darker than the other half.
Hi, while fixing another persons lcd tv i used lower rated power supply to try to fire up the tv ( picture-no sound) the bulbs ( actually cold cathode fluorescent ) lit up but only halfway. So sounds like the power supply for your backlight has gotten weak. You may try a workaround I've used on personal equipment, try turning down brightness on tv-this may,if your lucky, even out the brightness. hope this helped. Prodzilla
Mar 30, 2011 | Samsung LN46A650 46 in. LCD HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
No picture or sound. Red light comes on then goes off.
I had the same problem with my LTP227W and it is also about 4 years old. Took it in to be fixed and they found it was two capacitors in the power supply. Parts for this TV are not available anymore but they were able to repair the power supply. The TV works fine now. Hopefully I can get another four years out of this. Repair cost was $150.
Oct 24, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Televison & Video Logo
472 people viewed this question
Jerry Greenberg
Jerry Greenberg
