Question about Sylvania 6620LE 20 in. HD-Ready LCD Television
How do set TV to "over the air " or "antenna"?
    Top Expert:
  • Sylvania Master
  • 74,136 Answers
Hello
Just get into its setup window. Make an autotune function to it, after connecting it to external antenna. You can get all details by its user manual.
Posted on Feb 08, 2012
How do I switch from digital to antenna?
If you are in the U.S. all stations broadcast in digital. if you don't have a digital tv then you need a converter. So maybe you want to know how to go from cable to air antenna? You should be able to buy an antenna and roll of coax. Fasten the coax to the antenna and plug in to the back of the TV. Point the antenna in the direction of the tv station, I think some TV's may have a setting to air antenna, set to air. It should not receive a picture.
Sep 28, 2014 | Televison & Video
The aerial port does not work.
It is possible the tuner or antenna connection is bad---If you can call up the menu with the remote set needs to be switched from cable etc to air or antenna and channels programed------not on the rear input connection but for the tuner in the set (presume it has a tuner if antenna connection of any type is there.
Oct 29, 2012 | Televison & Video
How do I set TV to antenna - Vizio VA26L
The input should be selected as 'TV' to get any on-air transmission. Now the input is selected to Cable. Change it to TV. Refer its user manual for more details.
Aug 04, 2012 | Vizio VA26L 26 in. LCD HDTV
I dont want to use cable. I plugged a rabbit antenna and i get the message "Failed to receive broadcast (E202)
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
Jun 28, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I bought a new Samsung LED 40" Series 5 TV. However, after connecting to the tv cable line, i get message " weak or no signal" and not able to get any tv signals. What could be the problem?
You usually hear "weak or no signal" when the tv's input is set to air. Check to see if changing the input might help. Or if you are using an antenna to get your tv, then maybe your antenna is not powerful enough. The new digital signal is weaker than the analog, so antennas that once worked might not work as well now. Hope this helps!
Apr 06, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Shows "no signal" on my
when you say jack in antenna, I assume you mean you have an outide antenna. If you have never recived over the air signals before you won't now. If you have cable tv, then go into setup and set your scan channels to CATV and not Outside antenna, or what ever it might be called on your set. i need more infomation before I can give you more advice
Mar 17, 2011 | Televison & Video
I am having trouble recieving over the air digital signals. I have connected a 20 db amplified FM/UHF/VHF antenna to the cable/antenna coax connection, set the input to "TV", and set the TV to...
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Regards,
BElectric.
Feb 10, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV signal seems to "crack" with pixel distortion.
This is what digital signals do if there is not enough signal to paint the picture on your set. If you are using an antenna, then the signal coming from the station over the air is not strong enough or is being blocked by the trees and buildings. The TV needs a signal at least 60-70 % to get the data, and since the FCC mandated higher frequencies for over the air TV, the stations signal will not travel very far. You can try a better TV antenna, with a higher DB gain, but it seems to be a loosing battle for the present.
If you subscribe to cable TV and it is happening, then by all means complain to your Cable Provider as they should send yo a signal that will run your set.
Jan 17, 2011 | Sony KDL-46XBR4 46 in. LCD Television
Sylvania 6620LE 20 in. HD-Ready LCD Television Logo
203 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
