Question about Car Audio & Video
How does the almani HP 1 work - Car Audio & Video
My 1500 almani amp soon as i turn on sterio blows both fuses
Over powered: Winding's are compromised and you have short. Could be an insulation problem, but only a VOM test can determine the condition or state of the amp.
Feb 03, 2015 | Cars & Trucks
Why wont almani amp turn on?
Did you connect the power-on lead from the Head-Unit?
Aug 04, 2014 | Car Audio & Video
Almani protection light coming on
fix your ground make sure its thick as the power and its touching bare metal
Mar 13, 2013 | Almani Car Audio & Video
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
Every time i turn up my volume the red light on my kenwood kac9104d flashes and it skips beats i am pushing one 12 inch almani dvc 4ohms 500rms anybody know why it is doing this cause i just ordered two...
sounds like your speakers are "clipping" drawing more power than the head unit or amp can handle. Or the speaker coil is damaged. Turn off amp and slowly raise the volume, and see if it still does the same
Feb 01, 2010 | Kenwood KAC-9104D Car Audio Amplifier
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
A200 HP rating
yes the early models had 1/3 the later 1/2 but I think it was more a marketing thing to keep up with competitors the 1/3 always worked fine
Oct 28, 2008 | Hobart A200 Stand Mixer
I have two amps in my car a 1100watt and a 800 watt both are almani.I have not had any problems with the system until now and I have had it for about a year.I have no sound what so ever from any speaker in...
make revision in fuses holder box and confirm that responsible fuses are firmly inserted-also confirm good connection of power lead(+&-) are connected firmly.
Jul 26, 2008 | Audio Players & Recorders
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Apr 11, 2008 | Power Acoustik PS2-1600 Car Audio...
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
