Question about Canon PowerShot SD890 IS / IXUS 970 IS Digital Camera
CANON IXUS 970 IS
My camera won`t stop ticking! I`ve tried everything to turn it off! What is the problem with it??
  • 34 Answers
Maybe the lens has shifted, try taking it to Canon Service Centre, (it will be fixed FOC if it's under warranty) as it does not need any spare parts, just reassimbling the lens with the body.
Posted on Feb 05, 2009
Canon IXUS 970 IS will not recognise 2GB SD card although it used to do so
The memory card might have been damaged.If it was a problem with your camera it might not have recognized your 32k sd card.
So buy a new sd card.
Jun 10, 2012 | Canon IXUS 970 IS Digital Camera
Canon IXUS 970 IS Someone played with my camera & now everything is in Japanese. How do I change the language back to English?? Thanks!
Press the playback button (right-pointing triangle). Press and hold the FUNC/SET button and press the menu button. Use the cursor keys to select the language and press the FUNC/SET button.
The instructions are in the "Setting the Display Language" section of the manual (page 15 in my copy). If you need a copy of the manual, you can download one from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd890_is#BrochuresAndManuals
Jul 09, 2011 | Canon PowerShot SD890 / IXUS 970 IS...
WHAT TYPE OF BATTERY RECOMMENDED FOR CANON IXUS 970 IS
The recommended battery would be:
Li-Ion
3.7 V
1120 mAh
SKU: DCA-5L
Price is +- $15
Regards
Nov 28, 2010 | Canon IXUS 970 IS Digital Camera
Hello, my ixus 760 i always showing busy when uploading photos to my pc. Tried everything, please help.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 24, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
Canon sd card IXUS 97015
The best way to download pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo/video cataloging program.
Jun 06, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
How to plug back the lcd connector on a ixus 970
if it is a standard ribbon connector that you are trying to reconnect you will find there is a small piece of the connector that either slides up or hinges upwards through 90 degrees. this releases the clip pressure to reinsert the ribbon then closing it holds it secure
Mar 02, 2010 | Canon IXUS 970 IS Digital Camera
Canon IXUS video problem
Use a card reader to download them to a folder you create on your desktop.
Feb 16, 2010 | Canon IXUS 970 IS Digital Camera
Canon IXUS 970 IS Digital Camera Lens error? Any ideas on how to fix this?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 19, 2009 | Canon IXUS 970 IS Digital Camera
Lens error with Canon ixus 970 IS
Has anyone responded to you on this yet - I have had the same problem and don't know what to do?>
Apr 07, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Camera thinks memory card is locked
check the pins where the memory card enter, if they are all there (not bended) go to canon site and download the latest framework.
P.S, mack sure to use the right SD Card type as the camera is compatible with some types and with a limited size only.
Oct 01, 2008 | Canon PowerShot SD890 IS / IXUS 970 IS...
Canon PowerShot SD890 IS / IXUS 970 IS Digital Camera Logo
171 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
