Question about Xerox DocuColor 240 All-In-One Laser Printer
Colour 550 error 093-317 - Xerox DocuColor 240 All-In-One Laser Printer
U052
To try and resolve the U052 error on your PIXMA MP550, please remove the ink tanks and print head from the printer, then reseat them. If you still experience the same issue, please turn off the printer, unplug the power cord from the back and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the issue is still unresolved, unfortunately, the printer will require servicing to resolve the issue.
You can contact Cannon here: Canon Contact Us
This information originally from: My printer Canon MP530 stopped working with an Canon Forum (also has a walk through for removing the printer head and ink cartridges.)
Just so you know, the 530 and 550 are the same machine, except the 550 has a few small improvements.
Mar 31, 2014 | ErrorExpert
Afficio 1013 has error 550 problem
SC Code 550 - Standby temperature error 1
Symptom: Fusing temperature failed to
drop to expected level within a
given time (15 seconds, 15
minutes, or 25 minutes,
depending on mode) after
entering standby or low-power
mode.
Possible Cause:
• TRIAC short
• Fan not running
May 05, 2011 | Ricoh Aficio 1013F Copier
Error S C 550
I cant seem to find SC550 in the Aficio 450 service manual but it usually refers to the cleaning web.
You can reset the cleaning web counter in service mode but i would advise that you check the web first.
The web is located above the fusing unit and is a white colour oil impregnated material, it is in contact with the hot roller and usually lasts around 100k clicks.
Are you 100% sure you have the correct model number ?
Dec 19, 2010 | Ricoh Aficio 450 Copier
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Nov 09, 2009 | Canon imageRUNNER 600 Printer
My printer displays ribbon error. but there is ribbon inside
you can change which ribbon type is installed in the printing preferences of the printer driver.
make sure you have the right ribbon type selected.
CYMTKO vs. CYMTO, etc.
There is also a button that will auto detect the ribbon right underneath the pulldown menu.
May 26, 2009 | Fargo DTC550 Thermal Card Printer
Error message
The WGPX-550 doesn't support 2GB card. You can have Canada on a separate card (512MB will be big enough) and Canada includes the bordering US states
Dec 31, 2007 | Whistler WGPX-550 GPS Receiver
Xerox DocuColor 240 All-In-One Laser Printer Logo
618 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
