Question about Engines & Components for Dodge Ram 2500 4WD
I've got a 2002 dodge ram & ho 24 vavle diesel that the lower the fuel gets the harder it is to start why?
I removed the lift pump & install the dodge kit fuel pump sending unit comb. in the tank.
4 Suggested Answers
  • 69 Answers
SOURCE: I have a 1998.5 dodge 5.9 cummings diesel 24 valve
It was located on the drivers side of engine close to fuel filter housing, but dodge has been selling and installing kits that change it to the in tank style for quite some time, so if not on block it must have been converted at some time.
Posted on Jan 05, 2010
  • 2432 Answers
SOURCE: My 5.9 dodge cummins diesel won't start, I've replaced the fuel lift pump, and the fuel filter, turns over. But will not start?
I think air in the system may be the problem ,Does the filter housing have a bleed nipple, open it and work the lift pump till fuel flows with out air bubbles, it no bleed nipple crack the fuel filter output line and bleed from there.
Posted on Feb 07, 2015
  • 267 Answers
SOURCE: 94 dodge diesel all it has in fuel tank is the level sending unit, there is no pump in tank. Where is the lift pump
fallow the fuel lines and you will find the lift pump it is bolted to the frame
Posted on Aug 29, 2015
Most likely you just have air in the lines.Crack them open one at a time and bleed them with the fuel pump off and on till you get fuel.If it fires dont hit the throttle let it sit and idle and close the line.Does it fire up with a small whif of starting fluid?
Mar 17, 2013 | 1999 Dodge Ram
2000 dodge ram diesel 2500 . What is a fuel injection pump mechnical failure? a fuel valve feedback circuit?
This usually happens when the lift pump gets worn and fuel pressure drops below 7lbs and the injection pump has to work harder by pulling in the fuel and will destroy the pump,your is probably a vp44 fuel injection pump it needs replaced and they are expensive 1200.00+ but also change the lift pump or change to a fass fuel system,if the lift pump went out and you replace the injection pump it will ruin it in a short time.
The injection pump is not an easy job to change or for a novice mechanic as it has to be set in time with the engine at top dead center,and then the whole fuel system needs to be bleed of air.
May 21, 2010 | 1999 Dodge Ram 2500 4WD
I have a 2001 dodge cummins 24 valve that if it sits for a couple of hours or more it is hard to start, as soon as it starts and i shut it of it starts right up, had new injector **** and lift pump put on...
I have a 2002 dodge 3500 diesel and just replaced the lift pump and thr fuel filter . I blead the pump and it stared right up, but Ishut it off and now I cant get it to turn over.
Feb 08, 2010 | 2002 Dodge Ram 3500 Truck
99 ram diesel wont start
Did you check to see if there is power to the glow plugs if not then that may be the problem and if there is power when you cycle the key not to start but for the plugs to warm up you may have a bad glow plugs.
Apr 22, 2009 | 1999 Dodge Ram 2500 4WD
2004 dodge ram 2500 5.9 diesel hard to start
The lift pump is bad Check the fuel pressure with a test gauge.
Jan 04, 2009 | 2004 Dodge Ram 2500
Fuel presure dodge diesel ?
all i can tell you is that as long as you dont go below 4 psi you should not starve injection pump, this is a minimum psi though., 10-13 psi is average on my 2002 at service port.
Dec 27, 2008 | 2001 Dodge Ram 2500 Truck
2002 dodge ram 5.9 diesel
I had a similar problem with my 06 cummins 5.9, I had to replace the lift pump.
Aug 28, 2008 | 2002 Dodge Ram 3500 Truck
Dodge 3500 diesel lift pump
When the key is turned to the start position, the pump should run for about 20 seconds. Do this 3 or 4 times to prime the pump.
If it still doesn't start, the bad lift pump may have damaged the injection pump. Crack a fuel line loose (don't remove it) and turn the engine over, you should have fuel at the fitting.
May 31, 2008 | 1998 Dodge Ram 3500 2WD
Vehicle Parts & Accessories Logo
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
