Question about Procom ML300TBA Heater
Natural gas conversion
I just bought a ML300TBA heater. It is a propane based model. The store does not carry natural gas models. Is it possible to convert this heater to using natural gas? If so, how should I do it?
  • anthony guastella Nov 27, 2011
    i have a gas want to trade?
    Problem Solver:
I have a similar problem. But, I want to convert it to propane. I have a 5 burner vent free modelMN300HPA. If your are handy. I would consider shipping you the parts inside mine to install in yours. These parts are very simple to remove after removing the access panels. I have taken mine out already. Called procom then to no less find out the propane parts needed are not sold by them. I think only the injectors (5) the main valve (regulator) and the pilot are the only things need to change. When taking out the pilot this is easly done, By removing the nut on the supply line. And then bending back the retaining tabs to then slide back the pilot then it comes out of the assembly bracket. Injectors are simply removed. Regulator located at the bottom is a simple remove. The only other item that might be questionable would be the valve that selects the amount of burners you would like to operate. And I would think this would be the same and not need removing. Let me know if I can help. I would like to get mine converted to propane. Thanks Tom
Posted on Nov 06, 2008
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
Jan 12, 2016 | Heating & Cooling
I brougt glowarm space heater model HDB30PT for propane gas but I needed a natural gas space heater.Can I covert it to natural gas and how can do it for me
I'm sorry to report there is no gas conversion for your DESA heater. In fact, no vent-free (vent-less) gas heating appliance (that includes gas log sets) is approved to be converted from one gas type to another. If you bought it from a retail store, exchange it for a LP Gas Model or a refund.
Hope this answered your question and thanks for choosing FixYa.
Sep 20, 2011 | Desa International GWP20T GLOWARM Wall...
I have 3 natural gas fire places. i would like to know if i can change it to propane. i'm thinking i would just have to change the logs and hook a tank up outside. can some tell me if this would work.
Typically gas log sets are factory made for either natural gas or propane. If you want to use them on propane you need to find out if a LP conversion kit is available for your brand/model #. Ask the place where you bought them or ask the company that installed them (if you didn't put them in yourself). If they can be changed over to propane, then you will need to buy the propane tanks, regulator and gasline or just have your local propane company put in a pair of 100# cylinders for each fireplace (or 420# cylinder to service all 3 fireplaces) with an auto-switchover regulator. They can also do the conversion, if the conversion kits are available. Let me now if you have any other questions. Douglas
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
Conversion for Hayward H200 Ing Pool heater from propane to NG
I have a hayward h-2001 natural gas heater that I wish to change to propane. perhaps we can swap parts. 920-324-5652
Jun 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Can propane heater be made to use natural gas?
Yes, there are kits out for that but you will want to get a professional to do the conversion....he will have the proper tools and equipment to set it up so that it works safely for you...
May 31, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a ProCom FBN400TYLA vent free natural gas fireplace and want to convert to propane because the gas company wants too much money to hook up a line. Is this even possible?
Found the manual on line and copied directly from it:
Models FBN400 are equipped for Natural
gas. Field conversion is not
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Nov 15, 2009 | Procom QL300TYLA Heater
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Procom ML300TBA Heater: Liquid or Gas
Propane exist in a liquid state when it is under pressure in a propane cylinder. When the valve on the propane cylinder the pressure on the liquid is reduced and the propane reverts back to gas state.
Also, regarding the tank you need....
the owners manual probably states what size you will need but, with most heater like the one you have it will require a 100 lb tank (approximately 25 gallons). You will also need an inline regulator set to 11" to 14" of water column between the tank and the heater.
Jan 09, 2009 | Procom ML300TBA Heater
Yes and most larger hardware stores will carry the parts ( it should only be a connector and a small adjustment...cost...maybe $6.00 to do
Dec 08, 2008 | Dyna-Glo Heating & Cooling
Heating & Cooling Logo
163 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
