Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Pto will not shut off unless something is hook toit
Pto only shut off when hook up to most implements
PTO led on the dash lights up when i try to start the tractor. I replaced the PTO switch, but no luck. Its like the starter loop thinks the PTO is ON, but the switch is definitely OFF.
Sounds like something like the key switch is searching for a ground.Use a piece of wire hooking one end to the negative of the battery and touch the metal case of the key switch with the other end , turn the key and see if the pto light still comes on , Feedback from a bad ground can drive you crazy.
Jul 04, 2016 | Garden
Is it possible to convert my 735 Moco from 1000 PTO RPM to 540 PTO RPM?
you do mean a 100 rpm pto up to a 540 rpm pto correct ?
tractors that have the wrong rpm are difficult to speed up as your going to have to give up shaft power (Horsepower) to do this so if your implement is already drawing your hP down , adding a speed increaser is going to make things worse
some out of the "normal" box things ive seen folks using the belly mower take off instead of rear pto , belly mower take off's are sometimes a higher speed but again have less power than rear pto points
Nov 03, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
While mowing along my blades stopped turning. i shut the pto off and tried again. i noticed the battery light comes on when i turn the pto on. i let the machine cool off and tried again. the pto turns on...
Did it work right after you changed battery? It sounds like your regulator/rectifier isn't recharging your battery. When the battery isn't charging properly the pto wont work for long. If you have a multimeter, hook it up to battery while unit is running and check voltage on battery. When idle is high you should see more charge and vice versa. Please exercise caution when doing this. Hope this helps.
Aug 01, 2013 | Garden
Working on a cub cadet zero turn electric pto to blades, pto won't engage when pulling switch, can't find out why can get it to run jumping straight to battery if I put a toggle on this set up is...
go to partstree.com and they should have wiring diagrams for your mower, should be a switch or something if the clutch works when you hook it to a battery (seat switch, pto switch, parking brake switch, even the neutral safety switches) also check your ground hook ups
Apr 27, 2013 | Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 | Garden
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
46 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Bud H
Adam Plug
Adam Plug
Are you a Farmall Toy Expert? Answer questions, earn points and help others
