Question about Cameras
Samsung digital camera
Everytime I try to turn my camera on it clicks 3 * and my lens is stuck out screen won't come on either go in
  • 734 Answers
Digital cameras often have lens movement problems due to jamming or chipset overheated failure. Sell it as a parts camera to use its lcd screen and other parts still good.
Posted on Feb 08, 2012
  • 98 Answers
SOURCE: Stuck Lens
It seems that the lens is stuck.
If you can repair it i have the repair manual, if not i can repair this problem, I'm not shure if i allowed to send our repairadress in the Netherlands we replaced a few gears or repair the damage into the lensunit.
Posted on Apr 05, 2009
jonniewalker
  • 1031 Answers
SOURCE: my samsung L200 digital camera fell down on the
Try all of the below methods only if your camera is out of warranty. If it is still under warranty, DO NOT pull on your lens while turning the camera on, whatever you do; you will destroy it, guaranteed.
Be especially careful when dismantling a camera to avoid an electric shock.all the circuitry boards contain cmos technology components, that will fail if not operated on in a esp safe enviroment,
do not remove the covers in any case. even if you would manage to free the lensblock you will do damage to the circuitry board just by exposing it to static electricity.
  1. First, make sure your camera has fresh batteries and it is in recording mode.
  2. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
  3. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
  4. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
  5. Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
  6. If the lens doesn't extend at all or it extends and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a click as it pops back in place. Power the camera on.
  7. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a click. If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
  8. If none of the methods work, you can dismantle the camera and try to clean the lens. .
Posted on Oct 11, 2009
hichama9
  • 65 Answers
SOURCE: Camera lens stuck!
Hello Friend,
First i would let you know that the Brand Vivitar is one of low quality cameras, it's sad but it's true.
Now regarding the issue that you have with the lens, you probably drop it because this the only way to have the lens stuck. but anyway, to repair it it will cost you more than a new one. and again i suggest to buy a branded camera like Canon,Sony,Nikon,Panasonic ... these are top quality cameras and you will not have any problem for life except if you drop it ;)
Best Regards,
Posted on Oct 29, 2009
shockwave727
  • 262 Answers
SOURCE: zoom lens stuck out
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Posted on Nov 12, 2009
  • 421 Answers
SOURCE: polaroid i733 digital camera lens stuck open
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the
batteries. (obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Posted on May 30, 2010
Lens stuck
Please see this link for troubleshooting steps for a stuck lens.
And here's a video summary of the steps.
Apr 28, 2013 | Samsung S860 Digital Camera
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
Sep 07, 2011 | Samsung Digimax S800 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
