Question about Proscan 26LB30H 26 in. LCD TV
I have a 26lb30h proscan 26
I have a proscan 26" tv model # 26lb30h i plug it in and the red light comes on to say it has power then i hit the power button and the red light trns blue for a few secs and then the hole thang shuts down not red nore blue light and it acts as if it has no power what can i do to fix this and how much would it be to fix
  • Anonymous Mar 30, 2014
    Blue proscan screen stays on and power button won't work
    Top Expert:
  • Proscan Master
  • 74,136 Answers
Hello
There are two possibilites for this fault. The first one is shorted inverter transformer in the backlight inverter board. The second one is the fault with main board. For both faults, card base replacement is only possible. Check out which board has the short, and replace it.Image of the digital board is given here. Baclight inverter board can be located aty the panel itself, will be fitted vertically at the right or left side of it.i have a 26lb30h proscan 26 - 2_8_2012_5_34_32_pm.jpg
Posted on Feb 08, 2012
2 Suggested Answers
  • 2318 Answers
SOURCE: proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Posted on Jun 20, 2009
My Proscan will not turn on, the red off light stays on even unplugged.
hello kaylee, this may be due to a fault with the tv, there could be few things wrong i would get an engineer to have a look at or someone with electronic experience to check it over good luck
regardsshaun
May 11, 2012 | Proscan Televison & Video
Bought a 26 inch proscan from Costco on line. Tv won't turn on, led light is off as well. own TV approx 2 years wah can i do besides leave TV curbside?
Hi sglassgold,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated. I would advice also to replace the entire power supply for your convenience if finding technician there is not possible.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 14, 2011 | Proscan 26LB30H 26 in. LCD TV
MODEL 28LB30H POWER UP SHUT DOWN WITHIN A FEW SECONDS UNPLUG TO RESET AND DOES SAME THING
It goes into shut down can be caused by short circuits (in the power supply or in the backlight inverter), falied power supply module.
You need to do in-depth troubleshooting to locate the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 17, 2010 | Proscan 26LB30H 26 in. LCD TV
Proscan lcd tv model 26lb30h blows fuse on power board
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
I have the 26 Proscan tv and the power will not come on. There is no light and I have checked the circuit box and everything is fine with that. Help! this tv is less than a year old.
You need to take this unit in for service. You have had a failure in the power supply board and now the unit will not power-up. This requires the help of the service center to thoroughly test the unit and determine the problem You can find customer support for PROSCAN at this website. www.oncorpus.com. Go to the support section and tell them you problem and find out where you can take it for service. The customer service telephone number is 1-888-977-6722. I hope this has helped you with your problem.
Apr 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Help
The power cord easily falls out on my model, try twisting the power cord where it plugs into the TV until the red light comes on in the front.
Nov 22, 2007 | Proscan 19LA25Q 19 in. LCD Television
Proscan 26LB30H 26 in. LCD TV Logo
139 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
