Question about HP LaserJet 2300d Printer
Hp 2300d paper stops at exit roller - HP LaserJet 2300d Printer
    Problem Solver:
  • 8 Answers
Probable causes: First have you tried running the paper thru the manual feed tray and see if it stops at the fuser unit.. if so then proceed with checking the exit area of the printer(fuser) and make sure there is no obstruction blocking the path, could also be the fuser actuator, small black arm generally pushes the paper during it's delivery(exitiing) of paper.. Worst case scenario is a paper feed timing issue.. but first check the exit area of the printer and the paper tray.
Posted on Apr 04, 2014
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: help find installer softwareforhp laser jet 2300d
Pls start here. Click on the appropriate Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
FixinFax
  • 3085 Answers
SOURCE: I hear noise from the paper exit rollers as they turne
You need to replace fuser gears RU-5-0077, 78 and 79.
Posted on Aug 04, 2009
SOURCE: HP 7150 inkjet printer stopped loading paper.
Hello
Happy new year and start reading solution with Smile and trust.
Based on information you have provided I understand that your printer has stopped loading the Paper.I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
Please check the Following Link to get the guidelines
"How to Load Paper" its silly to ask you but its better to keep information updated
Try by Following the steps below to correct the issue:
  1. Disconnect power to the printer.
  2. Remove all photo paper from the Photo Tray.
  3. Push the Photo Tray completely into the printer.
  4. Snap the Photo Tray out (towards you) sharply.
  5. Reconnect power to the printer.
  6. Print a self-test on 8.5 X 10 paper.
  7. Engage the Photo Tray.
  8. From the Printer Toolbox, select Calibrate the Photo Tray.
If the above solution wont work then there something to do with the Adjustment/alignment of the Tray.
Paper is not picked due to the Try --
If you see inside there will be a small rubber which need to be clean by the spirit .. Check this out as well .. as i tried on my printer and it works
Do slow and with care --
If it works Vote me
Cheers
Tejodhar Atreya
Posted on Jan 04, 2010
Testimonial: "For some reason, pushing the photo/out tray in firmly and then pulling it out again firmly worked. Thanks!"
Feed switch switch seems loose on the cassette and not recognizing paper being loaded after i changed the pickup roller
When you changed the roller you knocked the sensor out of place. Normally when you change the roller you want to release the right side roller lock first so that you can retract it and it keeps everything in place. You will need to remove the roller and then move the sensor lever on the roller shaft until it is in the correct position and them reintall the roller. This is sometimes easier to do if you tilt the printer on it's back so you can see what you are doing. Remove the toner cartridge first.
May 17, 2011 | HP LaserJet 2300d Printer
Why does the paper come out wrinkled from HP Laser jet 3030
Problem: Paper jams as it exits printer, starts out as intermittent and gets progressively worse. Paper has accordion folds at bottom.
Cause: Fuser drives paper out faster than the worn out exit rollers can push it out of the printer. This causes the paper to fold up.
Solution: The rubber treads in the rollers wears down, making them smooth. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable. If problems persist, the rollers need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | HP Office Equipment & Supplies
Pager jam after 5 pages
clean the tunner or change the roller
Feb 05, 2010 | HP LaserJet 2300dn Printer
I have hp deskjet 2300d showing that their is a paperjam. I found no paperjam what do i do
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
Sep 09, 2009 | HP LaserJet 2300d Printer
Aug 03, 2009 | HP LaserJet P3005 Printer
I have a HP 950C Printer And Am Trying To Print on photo paper
It sounds like the printers rollers are slipping on the heavier paper, possibly because this paper is smoother then your regular paper.
Try cleaning the exit rollers on the printer with something like methylated spirits - if the rollers have gone shiny, then you can usually revive them by using some emery paper to roughen them up.
Jul 08, 2009 | HP DeskJet 950c InkJet Printer
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
How to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Dec 21, 2008 | HP Color LaserJet 2600n Printer
Printing is skewed and distroted
The drive rollers are probably contaminated, hardened or worn. You can try doing something through the manual feed; take a fresh sheet of quality paper, make a fat line across it with pure alcohol (not rubbing alcohol; too much water), let the printer pull the sheet in a few inches, then hold the paper to stop it, doing this several times before the sheet is fully pulled in.
If you are lucky, and you have traces of black on the sheet when it exits, you might have cleaned the rubber drive rollers a little.
Another possibility is, you may have a scrap of paper in the paper path causing problems but to check this, you will need some disassembly, not always a 'fun' project.
Oct 24, 2008 | HP PSC 2510 All-In-One InkJet Printer
Laserjet 2300d
Probally fuser needs replacing, they come out easy it is a the hot bit at rear, these just click out after removing rear door, upper heat roller will be marked if this is causing your problem
Another way to tell if it is crtridge or fuser (tt is one of these two) is to stop a print half way by opening cover when paper is halfway threw insides of printer (timeing, timeing). Then pull out cart see paper under it that is printed but not yet fused (rubs off) if no mark present then it gets on paper when it goes threw fuser, if mark is present then it is the cart.
Oct 20, 2007 | HP LaserJet 2300d Printer
HP LaserJet 2300d Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
