Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Pto on my 806 desial won;t shut off
In off it runs with nothing on it
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
Ignition acting funky
With many of these Tractors, as part of the safety B.S., much of the electronics run through the PTO switch. Power to the ignition runs through the PTO.
Jan 04, 2014 | Craftsman Garden
Blades won't stay ingaged
bad pto clucth overheating shutting off
Apr 07, 2013 | Cub Cadet Lawn Mower Electric PTO Clutch...
How do i remove the PTO from an IH 856. The lower PTO shaft broke and the unit will not slide out
make sure all the bolts are out should be 1 short bolt and 8 long bolts to remove pto after that it is stuck to gasket. short bolt is in lower left corner of housing
Dec 26, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
My Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
Aug 20, 2012 | Cub Cadet Garden
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Oct 11, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
When hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
Pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
113 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Tom Chichester
Rod Newman
Rod Newman
Level 1 Expert
Are you a Farmall Toy Expert? Answer questions, earn points and help others
