Question about Naxa Electronics NX-503 Television
Where can I buy a 300 ohm feeder connection (75/300 ohm) jack (11) antenna pad?
I have a naxa nx-503 portable 5.5inch t.v. and I need a jack (11) antenna pad to connect to a small portable antenna. 300 ohm feeder connection (75/300 ohm)
  • 734 Answers
On ebay?
Posted on Feb 08, 2012
Antenna cable missing for Panasonic sa-pm42 stereo
782d9ae8-52f7-4cc4-a661-56731bddb11f.pnge94ad7da-0a4e-4d24-aacd-af1ae2881119.png980b7cad-16b3-4152-9d9b-f008ef27d842.pngThere are two types 300 ohm and 75 ohm. Some amps have both types of connection.
The 75 ohm type use plugs and cables commonly used for TV aerials and Satellite dishes.
The 300 ohm type uses screw clip terminals where you attach a coloured cable.
All shown here: The FM socket with the thread on, uses a Satellite connector plug.
May 28, 2013 | Audio Players & Recorders
Coaxial FM antenna
Radio Shack has an
adapter catalog number 278-0291. It takes some effort to push the 278-0291
adapter onto the FM UNBL 75 ohm terminal so wait until you have the 278-0291
installed before you connect your 75 ohm coax on to your new adapter.
This will resolve your FM screw on F connector antenna interface issue.
I see others trying to
help suggest using a 300 ohm to 75 ohm transformer match unit, this isn't what is needed. Your receiver antenna input IS a 75
ohm input.
May 22, 2013 | Sony MHC-GX450 CD Shelf System
Curtis RT068 antenna
if a coax fitting used on the set 75 ohms, screws are 300.
Mar 29, 2012 | Curtis RT068 5 in. Portable Television
Where can I find an antenna for this unit?
External FM antennas can be had for as little as $7 for the a simple dipole version (looks like a "T") to a highly directional outdoor type for over $150 at your local Radio Shack below:
http://www.radioshack.com/search/index.jsp?kw=fm&f=Taxonomy/RSK/2032189&categoryId=2032189&kwCatId=2032057&fbc=1&filterName=Category&fbn=Taxonomy/Antennas
The simple $7 dipole is a "twin lead" 300 ohm type that many home stereos shipped with because they are inexpensive, take up little room in the box and work surprisingly well for all but the very distant of stations. These antennas are also found for sale in many department and some hardware stores too. Your stereo may not offer twin lead or 300 ohm hook ups (2 terminal screws near the ANT label) but only a 75 ohm connection (like your cable tv connections), in which case, you'll need an inexpensive 300 to 75 (terminal to cable) ohm balun (or matching transformer) like this one below:
http://www.amazon.com/Parts-Express-Push-On-Balun/dp/B0002ZPIOQ
or to go the other way - from 75 to 300 (cable to terminal) ohm balun like this one:
http://www.amazon.com/75-300-Ohm-Matching-Transformer/dp/B0002ZPIOG/ref=pd_bxgy_e_text_c
Please rate this reply if you found it helpful. Good luck!
Jul 01, 2010 | Philips FW-D5 CD Shelf System
Screen rolls and jumps
look at the back of your tv and see if you have anything in relations to verticle hold or horizontal hold. it would look like a round piece with a flat to put a flat screwdriver into . this way you can adjust your screen etc.
Mar 12, 2010 | Naxa Electronics NX-503 Television
300 OHM Feeder connection
A Portable TV uasually has a 3.5mm phone jack as the antenna input, if you can't find the proper matching adaptor, try to construct one using a 3.5mm plug & an antenna maching transformer solder each side with short lenght of 75 ohn coaxial cable
Jun 22, 2009 | Televison & Video
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Naxa NX-511
Yes, you can. I was able to get my Dish Network remote to work with my Naxa 574 TV. Just follow the directions for the remote and you should be able to use it.
Dec 12, 2007 | Naxa Electronics NAXA NX-571 Television
NX-574
Check if u are not on A/V mode, return to RF/TV mode and try tuning again, also check your antenna connexion.
Jul 06, 2007 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Where is CATV/Antenna switch?
if its not in the antenna mode settings its automatic or not compadable check with the manufacturer to be sure.
Nov 29, 2005 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Naxa Electronics NX-503 Television Logo
101 people viewed this question
Top Naxa Electronics Televison & Video Experts
Electro Med Services...
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
