Question about Janome Sewing Machines
Husky 9000 will not sew e.g. Top thread will not pick up bottom thread. have done all tension and threading and needle placement are as per manual and am looking for ideas as to what the solution could be. The machine has just come into my possession and looks to be in very good order has been cleaned and oiled.
  • sandra wolfe Feb 09, 2012
    looks like the problem is the hook tension, will have to take the bottom off the machine to make the adjustments.
    Genius:
  • 1,212 Answers
I assume you tried to lay out the lower bobbin thread in different ways, Is the lower bobbin mechanism functioning? Not just the walking foot, but the outer assembly outside of the bobbin that encircles it. Is the bobbin fully seated in the carrier and is the carrier fully seated?
They need to fully seat, kind of like nesting eggs. Even the large piece held by turn buttons.
Posted on Feb 08, 2012
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
redbeard00
  • 957 Answers
SOURCE: Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Posted on Apr 26, 2009
  • 6 Answers
SOURCE: Problems with lower thread tension
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
Posted on Jun 18, 2009
  • 152 Answers
SOURCE: Needle severs thread each time I start sewing
Take the thread completely off the top of the machine. Put in a new needle. Remove the bobbin. When you rethread the top of the machine make sure the presser foot (that rests on the fabric) is in the "UP" position and rethread the top. Also when you thread the top, put some "pull" on the thread as you thread it, don't just lay the thread in the tracks. You need to pull the thread with some taughtness through the machine so it gets into the correct places under the covers so you have good tension and good stitching. Then put the bobbin back in and make sure when you thread the bobbin case that the thread "clicks" slightly as you pull the thread into the metal tension area of the black bobbin case. Anytime a sewing machine breaks thread at the needle, you should unthread the entire top and rethread it because the thread can jump out of it's guides that are under the plastic covers and you won't be able to see it, but you will see very ugly stitching!!!
Posted on Nov 21, 2009
  • 1116 Answers
SOURCE: Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Posted on Mar 10, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
My sewing machine needle (very new one) keeps jamming every couple of turns of the needle - and the thread is very loose and loopy on the fabric. It makes a jarring noise
not quite sure how needle is jamming. I have had them break, had thread ball up underneath and caused needle to jam. Question is the needle in the right way, ie the flat side in as per manual, generally the flat side faces away from you. Sounds like your tension is not quite right if the thread is looping. Loops on bottom, bobbin tension, on top sewing machine tension
Dec 08, 2014 | Sewing Machines
In regular sewing my stitches are fine but when I switch to embroidery the top thread is loose and sometimes doesn't pick up the bottom thread. What can I do to fix this?
You may need to have it checked and tuned up. It doesn't cost much. I just had mine done for the first time because when I tried to wind a bobbin the needle stayed in sewing status. I bought this machine years ago and it only cost.80.00 for a tune up also.
Looking at the manual it says to go to auto and you can see the screen where the cloth guide position can be adjusted. Right under that is the auto tension with a + and -. You would need to increase the tension level. It says that this is also used for professional style embroidery in the same way.
I hope both of these suggestions will help.
Jun 03, 2014 | Janome Memory Craft 9000 Computerized...
Jams up when attempting to sew, making loud noise. Thread mass under fabric when able to cut loose from machine.
Thread jams underneath usually are caused by top thread tension issues. Things to check:
top tension discs are clean and no thread traces caught in there, tension is set to medium number usually 4 or 5 and that the top thread is running freely from the thread spool, correctly thread through the tension discs, and down to the needle. Lower the pressure foot and pull the thread from just above the needle; it should feel firm resistance if under tension correctly.
As you've had a good jam up, good idea to now remove the bobbin, needle plate and bobbin holder (refer to your manual if you have never done this before) and clean out the hook area well, look for any fine thread remants and brush out any lint etc. Oil the rotary hook area as per your manual. Now reassemble, and rethread everything again checking that the bobbin thread is clicked into the tension spring and that the top thread is through the tension discs correctly.
Also, pop in a new needle, flat shank to the back, then try again.
Good luck with your machine.
Mar 14, 2011 | Brother SE-270D Computerized Sewing...
My Kenmore stopped making stitches. I changed the needle recently to a Singer Universal regular point needles 100/16, but I dont believe that is different than what was in there before. I have a Model...
Why are you using #16 needle, that is very heavy duty? Did your machine pick up the bobbin thread correctly? Try a different needle, #11, (inserted facing away from you) is usually good. Make sure that you have decent thread and that it is the same weight top and bottom. Now rethread, with the presser foot up and when you have that done, with the presser foot stiil up, pull top & bottom thread, it should feed smoothly, now with the presser foot down, pull the thread, it should barely move. This usually seats the thread in the tension discs. Put your top tension at 3 and see if that makes a difference.
Jan 19, 2011 | Kenmore Sewing Machines
I bought a White Family Rotary sewing machine made in 1909. While cleaning it up, I unscrewed part of the tension assembly on the face plate not knowing that these can be very difficult to get back...
  • Set up your sewing machine on a table with good lighting available. Plug in the electrical cord. Insert a new needle into the shaft on the needle bar and tighten the thumb screw to secure the needle. The needle bar is the area on the shaft where the assembly for the needle thumb screw is located.
  • Step 2 Thread your sewing machine according to the manufacturer's directions. This requires slipping the thread through various retaining and tensioning loops to allow for the proper drag while sewing. There is usually one loop at the top to go through first, then a second above the thread tension knob. Bring the thread into the tension knob area and pick up the loop of the tension wire. Bring the thread back to the next upper thread loop and then down to the needle bar where you thread the needle.
  • Step 3 Wind a bobbin with the thread that you intend to use. You may have to partially unthread your machine to do this. Make sure there is tension on the thread while you are winding it so that the thread winds properly. Insert the bobbin in the bobbin case and place it in the shuttle race then draw up the thread with the needle thread to prepare to sew. The shuttle race is located in the lower body of the machine under where the needle enters the throat plate.
  • Step 4 Cut a scrap of fabric from the fabric you intend to use for this project, at least 12 inches long and 4 inches wide. Double the thickness of your scrap by folding it in half lengthwise. Insert your scrap under the sewing foot and lower the foot into position. Sew a seam approximately 6 inches long then remove the scrap to check the stitches. If the stitches are loose on the bottom, adjust the tension knob to a higher number for more tension. This is done by turning the knob so that the indicator mark moves to a higher number. If the threads are loose on the top you will need to make the opposite maneuver.
  • Step 5 Sew more seams on your scrap, stopping to check your thread tension for your stitches until you have stitches on top and on bottom with no discernible looseness.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Jun 17, 2010 | White Sewing Sewing Machines
    I have been using the zig zag stitch for appliques and all of a sudden the bottom thread which is a different color is showing on the top. I have rethreaded top and bottom threads, changed needles, cleaned...
    it sounds like no bobbin thread tension. there should be some resistance when you pull on the bobbin thread. if there is none or too little you may have some lint or thread caught behind the bobbin case tension spring.
    very carefully try and push the tip of a thin pin into the bobbin case tension spring and pick any accumulated thread or lint out.
    if the bobbin case spring is clean, try tightening the bobbin tension a little at a time until your zig zag looks ok.
    of-course all this is done after checking needle threading and needle for damage.
    scott.
    Jul 29, 2009 | Janome Sewing Machines
    Sewing Machines Logo
    219 people viewed this question
    Top Janome Sewing Machines Experts
    Tally Girl
    Tally Girl
    Douglas Plant
    Douglas Plant
    Eva Hack
    Level 1 Expert
    Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
