Question about Philips DVP3050V/37
What is the manufacturer codes? - Philips DVP3050V/37
    Top Expert:
  • Philips Master
  • 74,211 Answers
Hello
Try these links to donload its manual with codes.
retrevo.com
download.p4c.philips.com/.../dvp3050v.../dvp3050v_75
http://www.dataentryjobs.us/67948.html
Posted on Feb 09, 2012
What are the probable causes of DTCs P0014,P0300, and P1358?
Please refer to the links below for definitions and poss causes.
http://www.obd-codes.com/p0014
P0300
Random/Multiple Cylinder Misfire Detected
PossibleSymptons
the engine may be harder to start the engine may stumble / stumble, and/or hesitate other symptoms may also be present
PossibleCauses
A code P0300 may mean that one or more of the following has happened: Faulty spark plugs or wires Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector(s) Burned exhaust valve Faulty catalytic converter(s) Stuck/blocked EGR valve /
PossibleCauses
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back. If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Dependin
SpecialNotes
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly. A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the .box1 { overflow: hidden; position: relative; border: 1px solid #CCC; border-radius: 8px; padding:10px; background-color: #efefef; color: 000; margin-top:10px; } P1358
Trouble Code:
System:
Subsystem:
P1358 - (Manufacturer Specific)
Powertrain
Ignition System or Engine Misfire
DTC Description: (Cylinder No.2) - ignition Circuit Open Circuit
Analysis:
Likely Cause:
Cylinder 2
Open Circuit
Notes:
Site Instructions:
  1. Please note the list of automobile manufacturers at the left edge of the screen. The currently selected ODB code is for the Volvo family of autos. The codes for any particular vehicle make and model will be found under the manufacturer family, i.e. Dodge and Plymouth are part of the Chrysler family of cars and trucks.
  2. Also notice that just to the right of the manufacturer family list is a short group of OBD II codes. The highlighted Volvo OBDII code P1358 in this list is the currently selected code, and the information on this page pertains to fault code P1358. The other codes in the list above and below this code are OBD2 codes some of which may be related to the current trouble code and can be navigated to directly.
  3. Need to look up additional OBD II Trouble Codes, use the search box. Enter the 5 character fault codes in the search box and submit the search. You can repeat the search as many times as you need, one diagnostics code per search.
  4. Don't assume a particular OBD2 code means the same for other auto manufacturers as there are many manufacturer specific codes in use.
  5. If your fault codes are for a different auto family, select that vehicle series before searching for the diagnostics codes because not all OBD2 codes used by one manufacture are used by the other manufactures. The search only looks at OBD codes valid for the currently selected manufacturer family.
  6. If your automotive family is grayed out, the current OBD code, P1358, is not among those used by the current manufacturer. You can click un-gray at the bottom of the auto family list and then select the manufacturer for your vehicle before searching for your trouble codes.
Volvo Models by Year Include
Apr 04, 2016 | 2000 Volvo S70
Fault code 26
You will have to provide more information in order for anyone to help. As. Appliance Factory Parts says... "Fault codes can and do vary from manufacturer to manufacturer, even between models from the same manufacturer these codes may well be different."
Feb 08, 2015 | Washing Machines
PROSCAN MANUFACTURERS CODE
There isn't a "Manufacturer's code"
Each maker of universal programmable remotes has their own set of numbers for the various codes. Procsan might be 123 in URCs code list, but cold be 987654 in Memorex.
You need to start with the make and model of universal remote that you are using. Then find the code that that brand (the remote maker) uses for the make of TV that you have.
Sep 02, 2014 | Televison & Video
Vision battery date code
ALL VISION BATTERY MODELS
Date code stamped on top of battery container
X1 X2 X3 X4
Where X1 denotes year of manufacture A = 2001 B = 2002 etc.
X2 denotes month of manufacture A = January B = February etc.
X3 X4 denotes date of month of manufacture
Eg AH27 = battery manufacturing date 27th August, 2001.
Dec 12, 2013 | Exide Chloride Power Station (EXP2000) UPS...
A special set of code which distinguishes a manufacturer from other manufacturer is called as a "Manufacturer Code".
The identification of a manufacturer or shipper by a unique code is an important enforcement tool, and is critical for continued monitoring of key commodities.
Oct 30, 2012 | Televison & Video
Code 1633 keep alive power voltage too low
It would sure be nice to know what kind of vehicle you are talking about because that is NOT a standard OBD-2 fault code. If you got that code with an OBD code reader, you did not post the entire code....It should be "P1633" or "B1633" or "C1633". Also, in any of these cases, any code with "P1xxx" or "B1xxx" or "C1xxx" would be a MANUFACTURER SPECIFIC code that is not listed as a standard (generic) Diagnostic Test Code (DTC) by SAE J2012. These codes can vary from manufacturer to manufacturer and from one car line to another within the same manufacturer.
With all that said, from the description you have given, it sounds like the type of code that would set as the result of a very weak or dead battery or poor battery cable connections.
Jun 01, 2012 | Cars & Trucks
Tasco exp when you adjust the power up and down the crosshairs turn to does this scope have a lifetime warranty,where do u send it to get it replaced.
If you have a Tasco product that requires service or repair,
  1. First determine if your product was manufactured before or after 9/1/02. Tasco products manufactured before this date did not have a code for the year of manufacture. Tasco products manufactured after 9/1/02 will have this code (See Diagram 1 for help with determining this).
    The Tasco brand was purchased by the current owners in August of 2002. Only product manufactured after this date is entitled to complete warranty coverage.
  2. Call our Customer Service at 1-800-423-3537
    If your product was manufactured after 9/1/02 be prepared to give the Customer Service Representative the code number found on the product and you will be given instructions on sending your product in for repair.
    If your product was manufactured before 9/1/02 the Customer Service Representative will provide more information on the repair/replacement options available to you.
Identifying new Tasco product
Old Tasco products did not have a code for the year of the manufacture but new product does. Check to see if there is an alpha code of the year the product was produced.
Jan 25, 2011 | Tasco Optics
How to see manufacture date on NOKIA phones?
type the following code on the main screen of your 1600 to see the manufacture code IMEI and other details. the code is *#0000*
Jun 02, 2009 | Nokia 1600 Cellular Phone
What does computer code p1131 manufacturing control fuel air metering mean
Code p1131 manufacturer control fuel air metering, on a 2003 Ford Taurus. Where is part? Is there an easy way to see if it can be fixed without buying the expensive part?
Apr 27, 2009 | Ford Explorer Cars & Trucks
Do not have manual but I need the TV code to program a remote
The TV code for a remote is set by the remote manufacturer and not by the TV manufacturer. You'll need to check the remote manufacturer's website for a list of codes. Or get a new remote control which will have the list of codes with it.
Apr 12, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Philips DVP3050V/37 Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
