Start up error 42 - Computers & Internet
Windows vista startup error 42
Posted on Mar 07, 2009
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
How do I solve error 42?
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
May 31, 2014 | Precor EFX 546i Elliptical Version 4
How do I solve Error 42?
Model: All Models
Recommended Action:
May 29, 2014 | Precor EFX 5.17i Elliptical Cross-Trainer...
How do i solve error 42?
Model: All Models
Recommended Action:
May 29, 2014 | Precor EFX 546i Elliptical Version 4
Our precor elipitical is stuck at the top Error 42
Model: All Models
Recommended Action:
Mar 01, 2013 | Precor Efx-5.21 Elliptical Machine...
Error 42 on a precor treadmill
Model: All Models
Recommended Action:
Sep 13, 2012 | Precor 9.31 Treadmill
Finished workout on precor efx and during cool down ramp inclined and wheels started to hit front "base." I tried resetting the machine and started to get an "err42" on screen.
Model: All Models
Recommended Action:
Feb 17, 2011 | Precor EFX 546i Elliptical Version 4
What is the error 42:10? I keep getting this error and sometimes error 86:01, please help. When I start plotting a map or in this case early this morning on my first map I got this error 42:10, so I turned...
42:10 is carriage motor error, 86:01 is carriage jam. Check slider rods (both upper and lower) and carriage oil pads are lubricated, clean encoder strip. Is your printer is shaking too much? Place it firmly.
Feb 08, 2011 | HP Designjet Z6100 InkJet Printer
Error
Try to see if you can uninstall the DVD program, if any, and look this error
Error #42 RealPlayer Decoder was not initialized before attempting to use it
Jan 30, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
