Question about Toys
TMEC BD 50QT-3 SCOOTER - Toys
2 Suggested Answers
  • 1212 Answers
SOURCE: gas not getting to my engine on a TMEC BD 50 QT-3 Gas powered Scooter
Carefully remove hose connection at carburetor, if gas does not flow out of that, remove the hose from the tank barb and see if fuel is coming out there- if not, the filter screen soldered to the barb is plugged.
If you do get fuel flow, check the diaphragm on the carb, A simple carb rebuild should remedy it.
Posted on Feb 08, 2012
What it could be wrong? I have a 2012 Velocity 150cc the spark plug does not have sparks, What can I do to fix it?
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
GY6 150cc Ignition Troubleshooting Guide No Spark BD Technical Center
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Sep 29, 2016 | Motorcycles
What is error code E000110-0105 for a Canon imageRunner C4080 copier?
Hello Sir,
This error is about yellow laser unit:
Your error code translate:
E000110 = Polygon Error
0 1 0 5
1st line: Always 0
2nd line: Station where the error occurred (1: Y, 2: M, 3: C, 4: K)
3rd line: Main unit status when the error occurred (0: Activating, 2: BD control 1, 3: BD control 2, 4: Changing the speed, 3: Operating steadily)
4th line: Polygon control status (0: Suspension, 1: FG rotation, 2: BD control 1, 3: BD control 2, 4: BD Control 3, 5: BD control 4, 6: Phase locked)
In most cases you need to replace laser unit, but first, you need to check all the connections between electronic board and laser unit.
Best Regards,
Mar 27, 2015 | Canon Office Equipment & Supplies
How do i adjust choke and carb on a jonway 50qt-6 moped
You cant.adjust the choke itself if it is an auto choke, this is controlled thermostatically.
Dec 13, 2014 | Jonway Motorcycles
GEELY SCOOTER 50QT-15 2005 HEADLIGHT AND TAIL LIGHT DO NOT WORK
sounds like the controller is dead or has been knocked loose.
Aug 28, 2013 | Health & Beauty
50qt-15 repair manual
contact your local dealer if you don't have one get online and seek out dealers in your area
Jul 30, 2012 | Cars & Trucks
Instructions for sony bd remote control
You can also plug in your Keyboard/mouse (any usb type keyboard and/or mouse will work with a PlayStation 3). That will allow you to navigate the PS3 XMB Menu, as follows:
1) Prepare the BD Controller.
2) Go to: (Settings) > (Accessory Settings)...
3) Select [Register BD Remote Control].
4) Follow the on-screen instructions to register the BD remote control.
When the registration, or pairing, is complete, your system will assign a controller number to the remote.
Hints
  • You can register only one BD remote control at a time. If you register another BD remote control, you will overwrite information on the currently registered device.
  • After you reach the maximum of seven active wireless controllers, you cannot register or use a BD remote control.
  • Registering the BD remote control with another PS3 system will clear the device registration from the first PS3 system.
  • For details on the BD remote control, refer to the instructions supplied with the remote.
Jul 24, 2012 | Sony BD Remote Control for Playstation 3
Gas not getting to my engine on a TMEC BD 50 QT-3 Gas powered Scooter
Feb 08, 2012 | Motorcycles
How do i link up a playstation 3 dvd remote
Register Bluetooth® Device Register a Bluetooth®-compatible device with the system.
Registering a BD remote control 1.
Prepare the BD remote control.
2.
Select in_peripheral.gif (Accessory Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Register Bluetooth® Device].
4.
Only one BD remote control can be registered at any given time. If you register another BD remote control, information on the currently registered device will be overwritten.
5.
When the registration (pairing) is complete, a controller number is assigned.
May 08, 2010 | Sony PlayStation® 3 (80GB) Console
No power to coil or plug
Hi, Ash_2007 and the usual suspects are:
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
Gpr125 service manual
https://www.oemmotorparts.com/oem2.asp?M=Derbi
Jul 09, 2009 | 2005 Derbi GPR 125 Nude
Freezing scooter throttle
sounds like the cable needs to be lubed (oiled use 3in1 or wd40) the only thing is you need to remove the cable at the throttle end to do this good luck hope this helps you rember to leave a rateing
Jan 04, 2009 | Qianjiang QJ100T-C Motorcycles
Toys Logo
53 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
