Question about Lexmark T644 Laser Printer
What's your problem?: Lexmark T644 238.02 ERROR
Lexmark t640 Fehlermeldung 238.02 alles nach gesehen kein Papierstau was kann es sein?
Posted on Sep 09, 2013
SOURCE: Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
SOURCE: setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
  • 13 Answers
SOURCE: i have a lexmark t644
  1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
  2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
  3. Power the printer back on.
  4. If the printer goes to the Ready status, try printing again.
  5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
    • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
    • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: nvram mismatch
You have to install a brand new front display, the display board has a backup of the nvram, on boot the system board check the nvram and if it don't match it will return an NVram mismatch error
Posted on May 29, 2009
SOURCE: lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
Posted on Jun 03, 2009
My Lexmark Z2300 is giving me an error msg that the cartridge is in compatible. The cartridge is actually a Lexmark 14. Once I took the cartridge out and powered off, then powered back on and added th
were they 'refilled' cartridges ? Lexmarks are sensitive to that...they have a chip in their tanks that you have to change/reset....you can't just refill them with ink.
Tallon41
Sep 06, 2012 | Lexmark Z2300 InkJet Printer
Error communicating with scanner
If you're able to print fine, try using our Lexmark Printer Home software to scan. To access that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
If you're also having problems printing, it could be there's a communication problem. You might want to reinstall the software for your Lexmark Pro205: http://bit.ly/sW3OnE
Jul 04, 2012 | Lexmark Prospect Pro205 Wireless...
Lexmark X5650 cartridge error consult user's guide
Don't know for sure, but I found some user manuals on amazon, which can be helpful... take a look here: Amazon com lexmark manual I hope this helped you. Have a nice day
Mar 23, 2012 | Lexmark X5650 AllInOne InkJet Printer
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have loaded all new colour and the black cartridges but error message says 'black ink is very low'
Please make sure that your printer is updated. You can download and install the firmware update for your Lexmark Impact S305 printer by visiting the Lexmark website at http://bit.ly/s305fw.
Should the error continue to display on your printer screen, please contact Lexmark Technical Support Center for additional assistance.
Oct 14, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Error 1200 is showing
The 1200 error could be caused by a cartridge not properly inserted in the carrier, encoder strip got unseated from its position or there's something blocking the cartridge carrier path. Try to refer to this article in the Lexmark website to determine what's causing this and resolve the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
May 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
Lexmark T644 Laser Printer Logo
409 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
