Toshiba Qosmio QG10-133 powers on , but screen is compltely dead. I did't get any thing even on external monitor. Plz give me any advice. Thanx a lot
  • shaz4u Oct 24, 2008
    no thers is't any thing like that . even battrey is and can be charged. i can run computer on the battrey, only problem is screnn. chhers .
  • 749 Answers
Check the power supply on the rear..is the fan blowing..if not, the computer will overheat and not start
have you added memory that isnt compatable, if so , remove it and try to restart
have you updated anything recently? is the large main battery completely in it's slot? new USB device?
check a few of these things and post here again , i will help you all i can..
Posted on Oct 23, 2008
Hi i have problem with toshiba qosmio g25-av513 when i power on its show clear QOSMIO monogram and then start show saverl difrent colurs lines i try with external monitor show same .pls help me to fix this...
You can try downloading the most recent video drivers from the nvidia web site and installing them.
Other than that you would probably need to contact Toshiba tech support. Based on the information you provided it sounds like your video card is having a hardware issue. It's the reason you see the same lines on both monitors.
Apr 10, 2011 | Toshiba Qosmio G25-AV513 Notebook
How to set up multiple external monitors on a laptop
Since you only have one external monitor port, you need to use a video spillter, this will allow you to connect two or more external monitors.
NOTE: This video splitter will only give you duplicated displays. Please check the link below:
http://www.kvm-switches-online.com/video-splitters.html
Thank you!
Dec 29, 2009 | Toshiba Qosmio F45-AV412 Notebook
Verticle stripes on monitor--Toshiba Qosmio G25-AV513 PC Notebook
Following factors could be causing this problem and solution as well:
1) Cable Cut: check is to see if the cable between the screen and laptop is pinched or cut. Every laptop has this wire that runs through one of the hinges
2) If this problem temporary i mean for some seconds then it could be a short signal cut problem to screen which causes screen distortion
3) Connect an external monitor and restart the laptop. If you see the same strip on the external video, then that is the motherboard or the video card problem in case you have a video card on your laptop apart from integrated graphics chip
Nov 18, 2009 | Toshiba Qosmio G25-AV513 Notebook
Qosmio G25 Does not boot to windows
I extremely recommend DON'T do anything to the computer. Unless you plan on buying a new one anyways, don't bother fixing it on your own. blue screens are caused by one of hundreds of thousands of problems.
take the computer to a near by repair center and have them EXAMINE it. many of the issues can be solved, but be sure the is one of those cases. then get a quote on how much it will cost to fix.
You will need to do a Backup Before all your files are lost.
Good Luck
May 10, 2008 | Toshiba Qosmio G25-AV513 Notebook
No Display
I too have the same problem any ideas from anyone would help
Apr 13, 2008 | Toshiba Qosmio G10-133 Notebook
Toshiba EA60 laptop wont go in boot sequance, its stop after toshiba logo and gives a black screen with blinking curser in top lef corner
Its probably not the BIOS but the board warping beneath the CPU Socket or similar.. Dont flash it (BIOS) or it will probably kill the chip. Let me look up the model number...
Feb 12, 2008 | Computers & Internet
Toshiba Qosmio G10-133 PC
hi, the problem might be with the LCD connectors, of the LCD can be bad..??
Jan 03, 2008 | Toshiba Qosmio G10-133 Notebook
Respectable Sir,
DOES TOSHIBA LOGO OR SCREENSAVER SHOW AS COMPUTER IS TURNED ON.
BETTER YET DO YOU HAVE ACESS TO ANOTHER MONiTOR FROM A DESK TOP IF SO CONNECT MOINTOR TO THE LAPTOPS EXTERNAL MONITOR CONNECTOR (BLUE IN COLOR) MOUNTED ON SIDE OF LAPTOP OR BACK IF VIDEO IS VISIBLE ON THIS new MONITOR YOU HAVE AN INTERNAL VIDEO DISPLAY connector PROBLEM or bad display
Nov 13, 2007 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
