Question about NirSoft Freeware Content Advisor Password Remover
Remove this now please i don,t want it.. - NirSoft Freeware Content Advisor Password Remover
  • 7,365 Answers
Remove what?
Posted on Feb 09, 2012
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
I just need to know how to take the hub apart so can get the stud out
I'm sorry, maybe I was not clear, you don't usually need to take the hub apart! Please don't try as it may cost alot to repair. I'm assuming this is on a disc brake axle, however if not, please advise front or rear, disc or drum brake. If disc, remove the brake caliper, and then remove the brake rotor. This is all the disassembly that is usually required to replace a wheel stud. Once completed. you should be able to pound the broken stud through the hole, and then draw a new one through using a lug nut and some washers.
Jun 25, 2011 | 1994 Mazda 323
I cannot install and remove any type of applications(sis,sisx,jad,jar) in nokia e63 while installing it display a message'file corrupted' which is downloaded frm ovi store and while removing it...
Your phone has been infected with virus.I also had the same problem.Please enter *#7370# on your phone and restore settings and your problem is solved.Please don't forget to rate me as ' helpful ' if satisfied.
Jun 05, 2011 | Nokia E63 Cell Phone
Having trouble taking down the fan have removed the light and the blades cannot get the motor assembly down
Don't know which brand ceiling fab you have, but almost all mount the same way. You have completed most of what needs to be done. So, now you need to remove the ceiling cowl, that slides up and down on the down rod. There should be 2-3 screws in the top outer edge of the cowl. If you remove those, the cowl will slide down the rod. After that, unscrew the wiring nuts, that connect the fan's wiring to the house wiring. Don't forget to disconnect the copper ground wire, too. Then the ball on the end of the down rod shaft can be lifted out of the ceiling bracket.
MOST IMPORTANTLY, DO NOT ATTEMPT TO DISCONNECT ANY WIRES UNTIL THE CIRCUIT BREAKER FOR THAT CEILING OUTLET IS TURNED OFF. DON'T JUST RELY ON THE WALL SWITCH BEING OFF.
Hope this helped you in the removal of the ceiling fan. Please let me know. Thanks.
May 23, 2011 | Heating & Cooling
How to add freon to central air conditioner
dear sir
if you have some knowledge about air conditioner system then first connect hose with suction side of aircon pipe conector(valve) with Gage and second hose with cylinder and GAGE .during of this you must remember don,t forget to open valve before START this job then make your ac unit vacuum it should be 18-20 micron after vacuum fill freon (approxmatily 60-65 pci)
and check your aircon system,s evaporator all pipe has been cold not and any pipe is getting ice on it .if its reach pressure 60-65 psi AND YOUR AIRCON BLOWING COLD AIR then it,s good the close by cup nut on the connecting point and remove hose from connector and disconnect Gage from system .
(but please don,t do if you have not proper knowledge it can be dangour)
warning: if you don,t have knowledge to do this please don,t try
thank you
hope answer the question
Aug 22, 2010 | Whirlwind FH-778 Air Conditioner
I need help removing an empty ink cartridge from canon mp480 printer
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | Canon Pixma MP480 All-In-One InkJet...
I don like please remove from my desktop
Hi
I guess you want to remove office ?
i guess you are using win xp ?
if so go to start --> control panel --> add remove programs --> microdoft office -- > click remove
good luck
Jul 17, 2009 | Microsoft Office Professional 2007 Full...
Forgot HDD password? please help?
Boot the computer in safe mode. You will be able to go in and reset your password. and once you are running you can always install your normal password. Depending on the operationg system usually F10 or F2 or on some the DEL key will get you into the safe mode.. Good Luck easy do once you are in safe mode....
Mar 23, 2009 | Acer TravelMate 2480 Notebook
Fuel filter
under passenger side nr back wheel,
Jun 24, 2008 | 2001 Hyundai Accent
Computers & Internet Logo
21 people viewed this question
Top NirSoft Freeware Computers & Internet Experts
David Payne
David Payne
Are you a NirSoft Freeware Computer and Internet Expert? Answer questions, earn points and help others
