Question about Baby Lock Sewing Machines
Baby lock slows down to 0 after sewing a few inches
I can use the machine to sew a few inches and then it slows down to crawl, to nothing, then after it cools, I can use it again for a few inches and then it does the same thing. We have lubricated the moving part, the belt seem ok, motor runs well without the belt,
  • 5 more comments
  • Gabriella Feb 09, 2012
    motor runs ok without the belt, no smell, the motor is not hot
    something is making the motor slow down and then cut out but we cannot figure out what
    the foot pedal not a problem since the machine runs fine if I take the belt off, in other words it does not slow down without the belt
    I should have mentioned that we moved and have not used the machine for almost 3 years, that is why my husband lubricated the moving parts
  • Gabriella Feb 10, 2012
    at first the handwheel did not want to move easily, that is why we started to look for moving parts and oiled them, now it moves much more easily, the machine will sew minutes longer then before, then it slows down again and the wheel again becomes harder to turn, as if something was binding. However after it cools, you can sew again for a few minutes until the whee tightens up again
    the belt is not too tight, can move it almost 1/4 inch in the center
  • Gabriella Feb 13, 2012
    We took apart the stick length cam, sanded the inside a bit, since this was becoming too tight as it warmed up, runs ok now
    problem was the stich length mechanism
  • Baby Lock Master
  • 7,365 Answers
Have you checked
1.to make sure it's plugged into the wall outlet good?
make sure the power & foot pedal are connected correctly to the machine?
2.does the motor smell in any way?
when was the last time it was serviced?
Posted on Feb 08, 2012
  • the motor or the foot pedal could be going out,, or could be a bad connection inside the machine
  • can you turn the handwheel on the right side of the machine by hand?
    if you can turn the handwheel easily by hand,,then it's not the machine,,either the belt is too tight or too loose,, you should be able to move the middle of the belt between a 1/4 to 3/8 of a inch with the tip of your finger. now if the handwheel will not turn easly you need to oil under neath the machine anything that moves. & let it soak in over night, & also top of the machine,, even if you've oiled it already do it again. DO NOT OIL WHERE THE PARTS HAVE GREASE & DO NOT OIL THE BELT PULLEYS & AROUND THE MOTOR
SOURCE: need manual for Baby Lock Pro Line BL 6600 Sewing Machine
I contacted Ken by email, he found a website where I can get a manual for my machine, he's the greatest, should have given him the highest rank.
Posted on Sep 27, 2007
SOURCE: motor spins, but doesn't sew
Oh, mine did that a while. Then, I dropped a needle in it. I turned it upside down and shook. The one I dropped came out, along with another rusty one. I tried it, the needle worked again, but it didn't sew. Now it works, but again, doesn't sew. Try turning it up-sde down with the place where you put in the bottom thread and the other pannel exposed. My model id very, very old. It's an ELNA Transforma.
Posted on Nov 16, 2008
  • 43 Answers
SOURCE: I have a baby lock espire and it is only sewing in reverse how do I fix this problem
A couple of things to check befor
Posted on May 06, 2009
  • 43 Answers
SOURCE: I have a baby lock ea-605 serger
Assuming that (a) you have tried installing new needles, (b) the new needles are the correct system for the serger and the right size (typically size 14 for medium-weight fabrics, size 11 for lighter-weight fabrics), (c) the needles are installed correctly (inserted all the way up into the needle bar and facing the proper direction), then your machine is likely out of time and / or has a defective part such as an upper / lower looper. That will require professional attention to correct.
Posted on May 07, 2009
  • 52 Answers
SOURCE: it makes a rattling sound when I sew. It has been
If its an older singer featherweight it should sound pretty quiet but if its a newer 221 it has plastic or nylon gears and they can make a "barking" sound
Posted on Jul 16, 2009
My baby lock bl5260 serger starts ok but slows down and then stops
If it is a mechanical machine (not computerized), it could be seizing due to old oil that has dried. Mechanical machines, especially sergers, need frequent and thorough oiling (interior moving parts) using a good quality sewing machine oil. Avoid trying to run the macchine until you can get it serviced or the motor could be damaged.
Jan 05, 2018 | Baby Lock Sewing Machines
I need owners instruction manual for baby lock companion 1550 sewing machine.pls help where can i download free manual.
You can check with a Baby Lock dealer an online sewing machine parts vendor, or even eBay. However, it may be difficult to find a manual for your machine due to its age and perhaps even less chance of success for finding a free manual.
Baby Lock Manuals
http://www.sewingpartsonline.com/babylock-sewing-machine-instruction-manuals.aspx
Babylock Sewing Machine Manuals Instruction and Repair Manuals
Babylock Sewing Machine Manual PDF and CD
Nov 27, 2016 | Baby Lock Sewing Machines
How to adjust pressure foot on a Baby Lock BL6300?
Find the pressure adjuster on the top of your sewing machine. It is typically a screw or thumb screw, a dial or a metal plunger approximately 1 inch long.
Adjust the pressure, based upon the type of fabric you plan on sewing. Lighter fabrics use more pressure than heavier ones because they slip around more during sewing. Your normal pressure tension is typically set for medium-weight, non-stretchy fabrics.
Feb 24, 2015 | Baby Lock Sewing Machines
Baby lock bl4 736d serger slows down and stops
Your serger needs service. (clean, oil, adjust, etc.) It may be that the motor is not lubed well enough and as it is being run it heats up and expands which causes it to bog down and stop. I would take it in for service and "mention" this issue while you are there.
Sep 11, 2012 | Baby Lock Sewing Machines
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Jul 02, 2012 | Baby Lock Eclipse Serger
Using the cutter on the Baby Lock Evolve
As wide as you want, but anything over a few inches is going to be difficult to guide.
You will get a more even cut if you trim away most of the excess down to a few inches, like with a rotary cutter and mat.
Mar 11, 2010 | Baby Lock Evolve
Sewing Machines Logo
289 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
