Question about Whirlpool Duet GHW9150P Front Load Washer
Stinky washer When you shake the drum of the washer you can hear water underneath. Then you can smell stinky water. The water is sitting in the washer after each wash and smelling. This can't be normal.What to do? I have used the special tablets.
  • jchampion Feb 23, 2009
    Ugh, my entire laundry room reeks of sour water. I've tried the expensive tablets, Borox, vinegar, you name it, and I always check behind the rubber seal for small items that get caught in there. what is wrong with my washer?
  • wavydave Feb 24, 2009
    I have the same problem. The solution is to use bleach with your whites. It's better to use a normal amount of bleach frequently rather than a lot of bleach only once in a while.
Posted on Feb 24, 2009
  • 750 Answers
Hello trevchaznick
Welcome,
You said, When you shake the drum of the washer you can hear water underneath. Then you can smell stinky water. The water is sitting in the washer after each wash and smelling. This can't be normal.What to do? I have used the special tablets.
This is normal for many brands and types of Front load washers.
The water almost never empties completely from the inside.
I tell my customers, once a week run it with hot water and bleach even if you have to run it empty!
And then leave the door open when you not using the washer!
Whirlpool sells some products for this but I never use them.
Let me know how my method is for you.
Huuum
Please remember to leave a rating!
Posted on Oct 22, 2008
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
Stinky washer
you will always hear a bit of water in the tub after washing. buy a package of 3 tablets called AFRESH and follow the directions on the package. this product was designed specifically for the problem you are having. also, always leave the door open a little bit after washing. hope this helps.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
I noticed that my clothes are not smelling fresh, especially my towels. The washer has a musty smell even after running it with bleach. When I shake the washer when it is empty I can hear water. Is this...
if it is a Maytag neptune YES that sound is normal. especially when you rotate the drum by hand that is your balance ring you are hearing. Do you only use liquid detergent? if yes this might be your problem. it leaves a film around the drum. i would run 3 wash cycles with bleach and hot water. and then at least once a month with hot water and bleach to keep it fresh and also leave the door open so that it can air dry oder causeing bacteria love moisture.
Oct 24, 2009 | Washing Machines
How do I get rid of the stinky smell of my front loader?
The smell comes from your front rubber boot you must replace it toget rid of the smell.The water collects in the inner part of the boot and and sits there till it smells hope i helped
Sep 20, 2009 | Kenmore Elite 45986 Front Load Washer
We have a Kenmore washing machine, model 82984120, purchased in 1991 and have never had a problem. We have begun getting a foul smell after we finish washing. When I shake the basket, I can hear a bit of...
THERE IS ALAWYAS WATER PRESENT IN THE WASHER DRUM, RUN A LOAD OF HOT WATER WITH 3 CUPS OF BLEACH IN IT THIS SHOULD KILL THE MOLD THTAT IS CASUING THE SMELL, USE THE HIGHEST WATER LEVEL SETTING, DO IT TWICE AS NESS.
Sep 06, 2009 | Washing Machines
My Maytag washer has a defect, technican told me, that lets water get between the tub and outer lining and sit there and stagnate smelling terrible.
The water always goes from the tub to the outer shell, that is where the pump connects. Put a little bleach in the tub with some water, shake the agitator side to side to move the drum enough to circulate the bleach around the tub. Then pump the water out and then lower the hose down to a bucket to get the last of the water out. Feel around between the inner and outer drums for anything that has jumped out of the inner tub to the outer drum. You should be able to push the inner drum aside enough to get your arm in. You may have to open the top to get your arm in the space.
http://www.pcappliancerepair.com/model-display.php Check this site for your machine.
May 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer smells musty
there could be buildup in the outer tub causing some water to stay trapped and causing the smell, try running some loads uning Ahfresh or you can try pouring lots of bleach in there and letting it sit a while, then run it throu a cycle.
Feb 12, 2009 | Kenmore 23822 Top Load Washer
Water isn't completely draining
the water sound is normal ,to make the machine balance there is a liquid in the shell of the tub that is always there.As for the smell start leaving the door partially open and mold/mildew cant form.
May 30, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
223 people viewed this question
Dan Webster
Dan Webster
Sal De
