Question about Sharp Aquos LC37D44U 37 in. LCD HDTV
Sharp tv closed caption cant turn off - Sharp Aquos LC37D44U 37 in. LCD HDTV
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
Ask cable company than get a procedure to on off HD CCs.
Posted on Mar 18, 2008
SOURCE: Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Posted on Jul 29, 2008
ok had to post this one with reference to the above problems
My area St Augustine Fl. .. COMCAST (THOSE PAIN IN THE A--) SERVICE INSTALLED A NEW BOX IN MY HOME THE OTHER DAY ... I KEEP SEEING the box go thru dowmloads
then the very next day I started to see the colosed caption across my screen
SOLUTION ... with tv on and box on ( be in cable mode) press MENU on cable remote ,press power button, press menu again, look at screen and where it says caption make sure it is disabled
Mine was enabled ... change it and problem fixed ... I spoke to comcast finally after trying all day and they confirmed that with their new down loads to box it triggered the CAPTION to be ON
anyway problem was fixed ...
I read all prevoius posts and tried them all ... so may be this will work for problem that someone is having as of 10-9-2008 ( I could not believe that they could do that but they sure can COMCAST is just a PAIN in the A--
thanks to all who post solutions and I had to do my share and maybe be able to help someone else.
Posted on Oct 10, 2008
SOURCE: Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Posted on Feb 02, 2009
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Posted on Mar 17, 2009
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I turn off the caption on this freakin Sharp Liq. Crystal T.V.? I lost the manuel! IT'S NOT A SANYO...IT'S A SHARP T.V. MODEL # LC40E77UM
hi,
For switching off the closed caption option do the following.
1. Press CC on the remote.
• This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
• Press repeatedly until you select the desired closed
caption service as OFF.
ok
Feb 25, 2011 | Sanyo DS31520 31" TV
How to get closed captioning on Tv
Use ur remote turn on CC on the remote 1/2/3 CC 1/2/3 well get Captioning if the show have Captioning.
Jan 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I turn off spanish closed caption?
the close caption feature is different than the language in the menu.
Try to find the close caption feature in the menu and get it off. Now if she hit a button then chances are you find some button with that description in the remote control (close caption or text) make sure is off.
Apr 08, 2009 | Sharp 27K-S100 TV
No Closed Caps With HDMI Cable
The information the closed-caption decoder in the TV needs is not provided over the HDMI cable from your converter box. This means the TV's closed-captioning can't be used. But the cable box should provide closed-captioning, so check its setup menus. Contact your cable provider for more information if it's not obvious from the box setup how to turn captions on.
Aug 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp 17" TV
It's the Closed Captioning function I think. I've had the problem with my Sharp TV (and other TV's that have Closed Captioning function). Look at the menu or the manual to see how to turn off Closed Captioning. It might be marked as "CC".
Oct 06, 2007 | Sharp 25N-M100 25" TV
Sharp Aquos LC37D44U 37 in. LCD HDTV Logo
44 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
