Question about Panasonic KX-FL501 Plain Paper Laser Fax
My panasonic kx-fl501 fax message says please wait and the keys don't work
The phone works fine but I can't fax or do anything. Press fax or copy of anything. It just stays on please wait. I unplugged it and that is the message i have.
I realize this thread is old, but I just encountered the same problem with my Panasonic KX-FL501. Pressing #9000* does not work, as none of the key pads are responding. When I lift the receiver I get a tone. But the keys don't respond when I dial. Display shows "please wait"..... I've been waiting for hours.
Posted on Jul 07, 2015
  • 168 Answers
SOURCE: fax problem
How is the copy when you try to just make a copy of something? If it copies good, then it might be the senders machine.
If when you make a copy, and the copy is blurred, then it is probably your ribbon/ink cartridge.
If it is the cartridge, just replace the cartridge, and you should be good to go.
Hope this solves your problem.
Good luck.
Mac =)
Posted on Feb 09, 2008
  • 31 Answers
SOURCE: Error
try this
press menu #9000* 550 start
unplug the unit after you heard the beep for 10 seconds
call us at 023633636
Pantronics international corp. Philippines
Posted on Mar 11, 2008
  • 168 Answers
SOURCE: Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Posted on May 02, 2008
rscheutz
  • 54 Answers
SOURCE: User manual for Panasonic KX-FP81C Plain paper fax
The manual can be downloaded here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FP81
Posted on Mar 25, 2009
FixinFax
  • 3085 Answers
SOURCE: Fax Machine Panasonic KX-Fl511 a fax was sent
Unplug the power cord for 10 mins.
Posted on Jul 02, 2009
How do I change the date stamp that prints when I send a fax
Ring the person you sent the fax to and ask them to white-out the date printed and fill in the required date.
Alternatively, you could read the Operating Instructions (http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL501%20Plain-Paper%20Laser%20Multifunction.pdf) and check page 17.
Jun 07, 2009 | Panasonic KX-FL501 Plain Paper Laser Fax
Message on screen 'Message waiting'. Do not know what it means
press the message key it will show various messeage waiting messages by other extensions or alternative use *790#
May 26, 2009 | Panasonic KX-T7636-B Corded Phone
Won't fax
invert phone wires in phone wall outlet and try.
Mar 18, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic KX-FL501
90 percent of the time that is a phone line issue.
But, first thing to look at is see if someone has removed the phone line and placed the line into the extension of phone jack and not the one marked "line"
You may simply need to replace the phone line between the machine and jack.
Yes you may hear a dial tone, etc etc, but you are losing one of 3 things. Either some of the phone line voltage, phone line current or what is called decibel loss.
When you send, you make the phone connection like lifting the phone off the receiver, but the signal to receive must be strong enough for it to key the fax board modem to receive.
If you have another device plugged in on the same phone line. Try removig that item, ex, an answering maching, Credit card machine etc and see if it is interfering with receiving also.
There is a high percentage the phone line is the issue.
Some things to check on the machine itself. Make sure Junk Fax setting is OFF, Make sure ECM ( error correction mode) is ON. Make sure Secure Receive is OFF and manual receive is OFF. Those will be in your machine setups.
The Junk fax setting will stop almost all incomming faxes.
It is less likely a software corruption issue. But that is remotely possible.
Let me know please, Some other obsecure things that can cause this. But I think you will find one of the posted things will resolve your issue.
Mar 04, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
No phone dial tone
please disconnect power plug from outlet and reconnect it after few seconds(this will make master reset)
Mar 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Error
try this
Feb 07, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Failed Pick Up
use alcohol and dry cloth and clean all what lubricated,fax machines don`t lubricate!!!!!!!.after cleaning the fax will work properly
Oct 29, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic model no kx -FL 512cx fax machine
1-use fresh papers and fan it .
2-clean paper feed roller carefully.
3-confirm that no foregin object droped inside.(pins etc..)
4-confirm that gear train working propably and there is no broken gear.
Nov 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic KX-FL501 Plain Paper Laser Fax Logo
219 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
