Question about Seiko SKA192 Wrist Watch
My Kinetic watch stopped working.
I recently left my Seiko Kinetic watch on my dresser for several days only to come back and find that it wasn't working. I have always worn it and only taken it off before bed and then back on in the morning. I shook it for about an hour and a half only to have the charge scale go up to the quarter level mark. The next day it stopped mid day. I shook it for quite a while after that with no results. What can I do to fix it?
  • Anonymous Jun 02, 2008
    my kinetic watch from seiko is stopped working after i didn't wear it for several months. what I i do? HELP!!!!! it was cost me 500.00 dollars back then..... that made me mad. :(
    Scholar:
  • 110 Answers
I highly suspect and probably you also suspect that the energy storage capacitor needs to be replaced. My experience in working on these is that they are only good for about 3-4 years. I only replace with a new Seiko Lithum Ion battery. Check www.timelywatchrepair.com
Posted on Mar 07, 2010
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
Tip
How to charge a Seiko Kinetic with an electric toothbrush charger
This is the Sonicare "Advance" model charger.
Other chargers will work, but many do not open with screws, they instead are welded or glued shut and must be shattered to get open.
I use the Advance charger for my toothbrush and to charge my watches.
This model has 2 very simple screws.
And the inside is arranged such that a watch fits logically over the flux.
Photo 2 shows the bottom of the charger.
Photo 3 shows the same charger with the screws removed and the bottom plate removed.
In every model of charger there should be a rectangular section and a circular section.
The circular section holds the electromagnetic flux generator. That is what will generate the power to charge your watch.
In most Seiko Kinetics the Generating Coils lays beneath the 8 o'clock marker on the watch.
You would like to have that 8 o'clock marker pointed toward the 9 o'clock spot on the Circle.
(See Photo 5)
On other chargers and with other watches simply rotate the watch around stopping ever 10 degrees or so for 10-15 seconds, until the watch starts to tick in 2 or 1 second intervals.
It may take several days to charge your Kinetic if it was fully discharged.
I hope this is helpful
on Aug 16, 2018 | Seiko Kinetic watch
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
I have a Seiko Premier Kinetic Watch SNP005. The problem is that the date is supposed to change around midnight. Now the date changes around 9-10 in the morning. I have read the manual and the only...
Thank you for contacting FixYa.<br /> You will have to contact Seiko on this one. I would tell you to just change the date to the day before and then forward the time, but I think I would just contact them as it is such a delicate timepiece.<br /> <a href="http://www.seikowatches.com/technology/kinetic/index.html">http://www.seikowatches.com/technology/kinetic/index.html</a><br /> Best regards.
Aug 25, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
My Seiko Kinetic winds down in one week after weaking a years and is not recharging to run after one day of wearing.
It sounds like that it is time to replace the capacitor with a new Lithium Ion battery. Send it to Timelywatchrepair.com. Go to this web sight
Dec 29, 2009 | Seiko Kinetic watch
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Seiko SKA192 Wrist Watch Logo
4,735 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Mental Breakdown
Level 1 Expert
Are you a Seiko Watch Expert? Answer questions, earn points and help others
