Question about ION Audio iTTUSB Turntable
Annoying crunching sound devleloped during recording
I've been using my Ion ITTUSB for a couple of years now, and for the past 10 months have been ripping a large collection of my vinyls to a hard drive. I have got the turntable connected via usb, as the product was intended for use. Over the past month or so, however, I have been having problems with recording. Basically, when recording (I have the option in Audacity to listen while I record) I get a very annoying crunching sound which is obviously more noticable when a beat is playing or whatever, it's almost as if the record is skipping (which it isn't, I'm fairly sure). I have tried changing the usb lead, the usb port into which the device is plugged, the stylus (twice). I've even swapped the slipmats just in case it was a static issue! The records are scrupulously cleaned before recording so it isn't dirt on the record (and I've recorded a few less clean ones and not had this problem, even ones that where scratched wheren't doing this). I've ordered some new styluses of the internet, just in case the replacements I was using wheren't good enough, but wondered if anyone has a clue what could be the problem?
I'm running XP, and using Audacity 1.2.6.
I get the feeling it is an issue with sending the info from the stylus to the computer, rather than a problem with the vinyls. So can anyone help?!!!
  • AndyStan Dec 30, 2008
    Same here. However, it appears to be totally random. I can record two or three LP's with no problem and then it affects every track thereafter. I wonder if it's a static build up as the records are cleaned and so is the stylus. I even use canned air to blow away any dust. If I stop recording, switch it off and go back after a couple of hours the problem goes away (usually) and I can record the album that I was previously having problems with, okay.
    I think the problem is an electrical one - I don't remember having all these dust/noise/interference issues when all I had was a vinyl collection.
    Any ideas?
  • ste_knight Jan 19, 2009
    As stated, the vinyls are scrupuously cleaned before use, it is more like an electrical issue, as AndyStan has mentioned in his reply. Thanks for your help though.
It sounds like the same problem I had. I solved it by keeping the stylus free of dust by brushing it frequently with a soft camel hair brush..
Posted on Jan 10, 2009
My Ion ittusb has no sound while playing or recording. But the software it will record and play back? Have used different makes of software. Even tried it on a laptop to see if it was a PC problem. have...
I am not sure what computer system or operating system you are using. If you are using a PC with MS Windows try to go to the control panel from the start tab. Double click on the sounds and audio devices icon. Click on Advanced in the master volume box. If any mute boxes are checked, uncheck them and move the volume to the top. Try your system to see if you have any output. I hope this helps since I did not see any recommendations to check the master volume mixer.
Jul 14, 2011 | ION Audio iTTUSB Turntable
Will not record to a usb thumb drive or a sd card
Should it? I interpret the need for Audacity or EZVinyl software to mean there's a PC involved somewhere to do the actual number crunching.
Mar 25, 2011 | ION Audio iTTUSB Turntable
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
Trying to install a ion iTTUSB on computer but not
READ your quick start booklet. You need to go to control panel, open sound, there are three tabs- choose playback and make sure that the selected speaker is not USB Audio Codec-choose your speakers. In the Record Tab selcect USB Audio Codec.
Dec 15, 2009 | ION Audio iTTUSB Turntable
ION iTTUSB turntable has buzzing sound when I record
It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
Nov 28, 2009 | ION Audio iTTUSB Turntable
I want to know how to operate iTTUSB.
I think it's plug and play. Plug the record player in the usb slot, let your computer find it, turn on your recording program, drop the needle on the record.
Apr 03, 2009 | ION Audio iTTUSB Turntable
I'm not getting sound with my Ion Turntable
Ater spending several hours trying to correct the problem I replaced the USB cord and it worked.
Thank you for your reply.
Oct 06, 2008 | ION Audio iTTUSB Turntable
ION TTUSB05XL - Poor sound quality
the turntable has a built-in phono preamp so you don't want to run it through phono inputs in your receiver but just regular auxiliary inputs instead
Oct 03, 2008 | ION Audio iTTUSB Turntable
Appears to be installed properly but doesn't record
What computer, and are you using the ion software, or 3rd party software to record?
Keep me posted.
Dec 09, 2007 | ION Audio iTTUSB Turntable
ION Audio iTTUSB Turntable Logo
200 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
