Question about Whirlpool GS445LELS Gas Kitchen Range
Whirlpool Gs445LEMS oven will not ignite
The stove is working but the oven is not...
  • 1314 Answers
SOURCE: Whirlpool Super Capacity 465
you need to replace the oven ignightor trybroil and see if it works if it does the bottom ignightor is bad
Posted on Jan 20, 2008
SOURCE: whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: whirlpool gas oven sf302
Replace the glow bar ignitor.
Posted on Mar 05, 2009
Maytag317
  • 1136 Answers
SOURCE: whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 27, 2009
brnspncr
  • 67 Answers
SOURCE: oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Posted on Aug 03, 2009
I have a loc message on my whirlpool stove. The oven works but the stove top won't ignite.
double problem burners spark box or control switches or just one of them oven door lock is not open all the way for oven may need replacement
Oct 23, 2016 | Whirlpool Kitchen Ranges
Gs445lems wont ignite
The oven valve can be the problem if the coils in the oven valve are bad, even if only one side of the valve is bad the bake and broil will not work. If I remember correctly there should be somewhere around 50 ohms across the coils. if it is much more or much less this is probably the problem.
Mar 16, 2014 | Ovens
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven works sporadically
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool gas oven sf315pemb1- oven not heating
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Whirlpool super capacity 465 gas range model# sf377pegq5
Aug 20, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool range gas model GS445LEMS
i have the same problem oven comes on but goes back off. help
Jun 26, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool GS445LELS Gas Kitchen Range Logo
53 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
