Power supply from IBM EXP200 disk array. Want to use it to power a battery charger. The edge connector has markings for 12v, 5v, COM, COM1, COM2. there is one part of the tab that's separated by a cutout and has three small contact strips which are unmarked. The unit powers on, but no voltage is present on the edge connector when tested with volt meter. Which leads need to be connected to send voltage? Thanks
SOURCE: asrock dual core 775 vsta motherboard
Since the only thing connected is the power suppy and the CPU, this is often caused by a power supply unable to provide the power to the MB. You will need to swap out the power supply and that should take care of the problem.
SOURCE: CPU fan not turning with ATX 12V connector plugged in
u also tell which company motherboard u install.when u pulgged it got earthing . I face this problem with ASUS + AMD kit . This problem solve by doing proper earthing at 100 feet depth.
SOURCE: Power Supply Problem with -5V
Get the original power supply for that mother board, don't save money and don't fool around with the computer like that!!
SOURCE: problem com1 ps2 mous and keybord
Well firstly I'd try another usb port...
Secondly there are loads of usb-ps2 connectors, theyre very cheap, just go to any computer store and buy 2, see if that helps.
I hope this solves your problem,
Yannick
Without seeing photos it's a bit difficult to say.
I would add a pic of the power supply, but I don't see a way to do that. I also can't see how to change the category from Motherboards to power supply. i think Motherboards was chosen by the site based on my comments regarding COM which in this context I think actually refers to "common".
Hi. There is an option to add a picture, at the bottom right of the text box there is a little camera icon, click it and it asks for a picture.Or you could send one to this email address.stuart (dot) bassett2 (at) virgin (dot) net
