Question about Jensen VM9510 Car DVD Player
Wont play dvd jensen vm9311
I tried toggle,gounding what else can i do
  • 1,586 Answers
You can bypass all that. Here's how:
This will work without having to do anything to the pink wire - just tape it and leave it alone. But the next time you unhook your battery cable you will have to put the code in again.
Put in DVD
When the blue screen comes up, hit STOP twice on the remote
punch in 1,2,6, and 4
hit DOWN 1 time
hit PLAY/ENTER (although you can't see it, this turns off the parking brake bypass security feature)
**at this point the display became visible and you will now see the menu which makes it much easier.
hit DOWN one more time to change macrovision
hit PLAY/ENTER
hit SYS SETUP twice to save and exit menu
From now on, you can just put in a movie and it'll start - no more grounding or toggle switch procedure, and you don't have to use the e-brake.
Posted on Oct 22, 2008
BRAKE BY PASS FOR JENSEN VM9311
daughter formated my hard drive by mistake got no recovery disc but reinstalled xp but got no sound drivers
Sep 21, 2009 | Jensen VM9510 Car DVD Player
Jensen vm9311 motorized screen wont close
no it's not your battery it is in the screen itself , the motorization is broken or damaged . You will need to get that repaired by either taking it to a repair shop in your local area that services jensen products or send it back to the company. If you choose to send it back to the company you will need to contact them first to get a return authorization number .
Audiovox/jensen 1-800-645-4994
Jul 04, 2009 | Car Audio & Video
I need to bypass brake for the jensens vm9311 so i can watch movies on drive
ok if you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 29, 2009 | Jensen VM9510 Car DVD Player
Video wont play
Go to www.google.com then type JENSEN CODE choose the first one on the top.
Mar 22, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9311TS
try pressing the reset button.
Sep 07, 2008 | Jensen's VM9312 Car DVD Player
Car stereo
go to the radio press setup on your remote then press 543210, a secret screen will pop up press the hammer and skrewdriver,u will see brake overide put it on the on position,thenpress the X at the bottom of the screen,then your all set.
Jul 08, 2008 | Jensen's VM9312 Car DVD Player
Wiring plug
try ebay thats where i got mines
Jan 01, 2008 | Audiovox VM9311TS
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Bypass brake for a jensen vm9311
Don't pay for it....Just read it:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
(Sorry Jack Sap, but this stuff should be free...)
Oct 13, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311 AM/FM/CD/DVD
you are mising to power on the factory amp.
Apr 25, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9510 Car DVD Player Logo
179 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
