Question about Electrolux Washing Machines
E40 ewf1083 clicking sound and error message e40
3 Suggested Answers
SOURCE: electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Posted on May 10, 2009
techbuster
  • 5081 Answers
SOURCE: E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Posted on Mar 10, 2010
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
Electrolux ewf1083 stops mid cycle displays e10 .press start button and continues but can happen up to 4 times per wash.any ideas?
We had the E10 error on EWF1083, I opened the top cover and looked into it. It's the 2 way solenoid valve and should be a easy replacement. Looked on ebay and $59 for the part ex postage
Oct 12, 2011 | Washing Machines
E 40 code error. Just keeps clicking then error message?
e40 is the alarm if machine started with door open. door lock may be faulty or connections/ wiring to it. possible for door ******/handle to come mis aligned in the door you have to split the door to check the handle shaft has not come out. watch where the springs go. the clicking is the electronic trying to lock the door.
Aug 03, 2010 | Zanussi ZWF1440 Front Load Washer
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
Electrolux ewf1074 error e40
Apr 09, 2009 | Electrolux Washing Machines
E40 error message on Canon DR5020 scanner
The error code E40 is caused by communication failure between CPUs- " Can't communicate with CPU on on Pick-up control CPU(80_SUB)".
The solution is" Check the connection and replace the PCB." This solution also applies to error codes: E41, E42 and E44.
Hope this information is helpful.
regards, TechSatya
Jun 30, 2008 | Office Equipment & Supplies
Error message
e40 fault code is water level too low during heat which is very strange to appear at start-up. does anything else happen? without being certain, points to a main module fault
Dec 23, 2006 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
