Question about HP Designjet T1100ps Printer
Hp designjet t100ps, loading paper
How do you load roll paper
ctf1800
  • 4402 Answers
SOURCE: HP designjet 1055cm/plus paper reload
sounds like the eof sensor is bad
Posted on Jan 07, 2008
  • 48 Answers
SOURCE: HP designjet 430 E Plotter
The reason it could be the main board is that it tells the front panel lights what to do. This seems like a logical problem the printer is having, usually things freeze when internal memory is bad. Surely have the main board replaced. There is a part of the internal programming that it cant get past. Compare it with trying to read a sector of a cd-rom that is scratched.
Posted on Oct 21, 2008
  • 53 Answers
SOURCE: Media Rejection
edgie46,
I have some bad news for you. The media sensor is faulty. This sensor is not sold seperatly. The entire pen carrage (head) has to be replaced at quite a cost.
Your part number from an HP parts supplier is C4713-60039
Its strange that is a refurbished machine with a faulty carrage. Maybee you can claim under a warrenty
Posted on May 25, 2009
  • 22 Answers
SOURCE: HP DesignJet 430 wont accept media
This is the problem with the sensor. It tries to read the size of the paper, the sensor is on the side of the carriage assy(cartridges are installed on this assy). You can try cleaning this sensor or get it replaced or some times the service center will replace the carriage unit as a whole.
Posted on Dec 01, 2009
Testimonial: "Is there a specific proceedure that I would use to clean the sensor?"
  • 123 Answers
SOURCE: HP DesignJet 430 rejecting media
When you load the paper, the carriage edge detector measures exactly where the right edge of the paper is located. Then the paper is rolled forward and the edge is measured again. If there is a difference in the measurements, the printer assumes the paper is not loaded squarely and rejects the paper. After you load the paper and the printer asks you to align the paper, take your time, release the paper with the release lever, and line up the right edge of the paper with the right edge of the paper roll. You might have to do it more than once to get it to load. Some plotters are very sensitive and others are more forgiving.
Posted on Apr 15, 2010
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Paper
A T7+ is a drop and load terminal. Simply open the lid, drop the paper roll in, feed about an inch of the paper out from the bottom of the roll, then close the lid.
Feb 20, 2012 | VeriFone (M19755014US1) Magnetic Card...
Just want to get a new roll of paper to feed in
Simply press down on the spring loaded button above the F1 key on the right side of the unit, next to where the paper feeds out of its slot - you may see the symbol of a roll of paper and a right arrow. Then after you open the new roll of paper, just place it into the cavity with the end of the roll coming out from underneath the roll itself, towards the serrated cutting blade, leaving a small amount of paper (2-3") sticking out of the top of unit. Now close the lid until you hear it click closed, and the button you pressed to begin with has returned to its 'up' position. Your paper is loaded and you may resume normal operations.
Feb 22, 2011 | VeriFone VX510
Want to know how to load thermal paper on my sharp Fax model FO-71
1 - Grasp the finger hold and pull up to open the operation panel.
2 - Flip up the front paper guide.
3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
4 - Unwrap the roll of thermal paper and insert the paper shaft.
5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
• Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
come out blank after printing.)
6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
7 - Make sure the paper comes out straight, and then flip down the paper guide.
8 - Close the operation panel, making sure it clicks into place.
• FO-71: A short length of the paper will be cut off.
Dec 01, 2010 | Office Equipment & Supplies
Sep 25, 2009 | HP DesignJet 430 InkJet Printer
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Loading paper
I know this product and I have serviced it before.
I am a retired Xerox Service Representative.
Can you give me more details about this area.
I am not familiar, "by a roll of paper."
This machine can be fitted with one or two paper trays and has a by-pass feed tray, and a document feeder.
I do not know of roll paper that can be fed in this machine.
Thank you, I ook forward in hearing from you to resove this problem.
Mar 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
How to load paper
Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
HP Designjet T1100ps Printer Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
