Question about Maytag Refrigerators
Where is the reset button on a Maytag performa refrigerator
Model PTB1953GR
  • 131 Answers
SOURCE: Maytag Performa dishwasher
Check the float switch.
Posted on Mar 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Posted on Mar 27, 2009
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
SOURCE: looking for heating element breaker or reset on a performa dryer
you have to take off the back its to the bottom left
Posted on Aug 31, 2009
  • 574 Answers
SOURCE: Does Maytag Performa MDE3500AYW have a reset
may or may not be your element could be a thermal fuse for the element.
Posted on Sep 02, 2009
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
Why my Maytag model performa, washing machine fill
Check drain hose not too low ...Syphon Effect....Good luck
Sep 29, 2009 | Maytag Performa PAV2200
Looking for heating element breaker or reset on a performa dryer
Aug 31, 2009 | Maytag Dryers
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frig recall which model? Maytag refrigerator MTB2156GE* heard report of recall due to possible fire hazard
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with AND Model Numbers BEGINNING with Side by Side
Refrigerators AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ ARS, CS, JC, JS, MS, MZ, PS Top Freezer
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ AT, CT, MT, PT Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
Mar 10, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Set wrong load setting
you may have overheated the motor,try leaving for an hour or so and try on spin to see if it starts.hope this helps.
Mar 14, 2008 | Maytag Performa PAV2200
Refrigerators Logo
118 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
