Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Won't spin heavier loads
Kenmore Model 110.47512600 or Whirpool Equivalent on tech sheet of GHW7100RW0.
Was experiencing wet clothes at end of cycle. Removed foreign objects from water pump. Got the f28 error code because I tried running it with the front and rear panel off and the grounding switches weren't being depressed.
After reinstalling the panels and trying it, I would still get no spin operation but the unit was draining. I would also occasionally get the F1 error code.I ran the diagnostics and the unit would spin and drain fine during the test while empty. Unit continued to give an occasional F1 error. Checked wiring connections on CCU, Motor Speed Control, and keypanel. I also checked the pressure switch contacts and hose, and all checked good. I decided to replace the main CCU.
Now after replacing the control, I have determined that a light load of towels or sheets will spin fine, but 3 pairs of jeans (slightly heavier load) never seems to get to the high speed spin, and the clothes end the cycle wet. Not getting any more error codes after the control has been replaced, and don't see any out of balance switch on the wiring diagram, so not sure what is happening with the heavier loads. The unit is level and solid on the floor, with all counterweights in tact. I am wondering if the rpm of the motor is not able to get to speed due to the load, although it is in no way overloaded. Unit drains fine, into a standpipe 40" off the floor, and isn't airtight. One other thing to mention is that I have a slow drain system, with a floor drain right next to the washer. When the unit drains I will occasionally see the water backflowing out the floor drain a bit, but never out of the top of the standpipe, so I don't really suspect back pressure or backfill as the problem
Any suggestions?
  • 1 more comment
  • whisky7 Oct 23, 2008
    Correction, his unit is an HE2 Extra Large Capacity Washer
    I am curious as to what controls the actual spin speed? I know that the motor speed control board controls the motor, but I am questioning whether there is a sensor (tachometer or such) the checks the tub speed, and whether there is a sensor within the motor speed control board that measures the current draw of the motor during spin, to sense an out of balance load and adjust it's speed?
    I just can't understand why the unit spins fine empty or with a light load, but fails to spin properly on the heavier, yet not overloaded loads?
  • whisky7 Oct 31, 2008
    Yes, of course HE detergent is being used. If not we would be getting a suds error on the control.
    Thanks for at least attempting to get to the bottom of this problem, but I also posted this problem at another website, and received help within 24 hours. The problem has been isolated to either motor windings increasing in their ohm reading during heavier loads, or a rear bearing that binds in a heavier load. I personally do not feel that the rear bearing is an issue, and the washer has been spinning fine pretty much every other load.
    Due to cost of motor, the washer will be used "as is" until a permanent failure happens.
I would like to hear if there has been a permanent fix to this problem, i too am having this exact same issue. i changed the drain pump, and the ccu board and still wet clothes at the end of cycle?
Posted on Oct 23, 2010
    Sergeant:
    Champion:
  • 324 Answers
Are you using he soap?
Posted on Oct 31, 2008
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Error F28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Whirpool Cabrio washer - UL code, but I redistributed load & clothes still wet. What could causes wet clothes after spin cycle?
the washer has 2 speeds on spin cycle apparently your did not shift to high spin or final spin l
Apr 21, 2018 | Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
I own a Kenmore washer Model 110.22722100. The last couple of weeks, it leaves the clothes wet. It drains like it is supposed to and spins. What is causing this to happen?
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Here is the part you will need.
Nov 28, 2010 | Kenmore Washing Machines
I have a kenmore front load washer model 41744052500 the other day i did a load of wash and when i went to the drain cycle it worked fine but whenit went to spin it went right a couple of times then left...
tub was out of balance remove some of the heavier clothing and re spin! and in the future donlt try to run so much through it that are heavier items when they are wet
Jan 12, 2010 | Kenmore Energy Star 44092 Front Load...
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Feb 13, 2009 | Kenmore 23822 Top Load Washer
Noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Jan 12, 2009 | Kenmore 43142 Front Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Washing Machines Logo
258 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
