Question about T-Mobile Sidekick
My screen lights up but nothing shows up
I turn it on and nothing comes up... i tried shakin it and it came back, but if i flip the screen to hard the screen goes, away.... whats the problem how can i get it fixed, and how much will it cost???? at low prices
  • 3 Answers
U need your screen tightened and all you have to do is buy the screw driver and do it your self its easy and you save money
Posted on Nov 29, 2008
I have a flip slide hd S1240W that has not been charged up in a long time. I have tried to charge it and attempted to reset and then charge. All that is happening is a red flashing light but nothing at...
Try removing the batteries, plugging into your computer, popping the batteries back in, and removing. Wait 5 minutes, and plug back in! This should have an affect!
Oct 06, 2013 | Flip Video SlideHD S1240W HDMI Camcorder
When you turn the key you get nothing no click or anything whats wrong?
check n safty switch . or try shakin the shifter knob while trying to start.
Nov 23, 2011 | 1996 Chevrolet Suburban
Why is my ps3 160 gb not working.. the green light comes on. but takes 10s to come off. there is no yello light. maybe its the hdd . . . there is nothing showing on the screen
Hi there, try to do a hard reboot on your system. I suggest you have the system turned off, and when you power it up from the system itself hold the power button not just push it. It will beep and turn on but while you are holding the button it should beep beep again and turn back off continue to hold the button and it should boot up 1 more time. or you may have to let go of the button and hit it 1 more time, but it may help your situation
Feb 04, 2011 | Sony Playstation 3 (PS3) Console
My dell dimension 2300 powers on,but nothing shows on the screen and i just got a brand new power supply for it.Also when i turn it on the power light isn't lit and it sometimes works.
Could you please post back with the status of four lights at the back of the system title ABCD. Also does the system shows the dell logo on the screen as and when the power light comes on.
Try removing the memory and disconnect the HDD and the optical drives from the motherboard and then power on the system. If the system comes on reseat all the above components one by one.
Thank You for using Fixya
Proton
Jul 12, 2009 | Computers & Internet
When I turn my V6000 on, I have power lights and the fan starts for 5 secs then shuts off. Nothing appears on the screen!
Sorry to hear about your V6000 problems.
If this problem has just started and all was OK before this happened.!
1. Remove all media from drives.
2. Remove battery and A/C power input.
3. Flip unit over and remove the memory.
4. Disconnect the CMOS battery.
5. Remove the Hard Drive.
6. Flip unit over and Press the Start Button for 30 seconds.
7. Flip unit over again and re-install the Hard Drive, Memory and last, the CMOS battery.
Note ...
8. Reconnect the unit to the A/C input supply voltage.
Leave the battery out for NOW !.
Flip unit and try to start with the Touch Pad Led's. This should bring up Quick Play.
If your unit starts and you here several beeps,
Don’t worry, !! You should be able to access the BIOS screen. You can reset your date and time.
If you are still not able to start unit, drop me a email and I will try some other ideas.
Hope this works for you. !!
Try it, It may work !!
John Ray
john@johnrraycomputer.com
Readers please rate your information, even if you disagree, it shows the technician, you care enough to respond.
Thanks.
Jul 09, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
Display on pearl flip when closed is always black
John-
It is possible the backlight or the LCD itself got damaged. The good news you is you can replace it.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
Jun 03, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry pearl flip got wet
Sorry to tell you but the back light on your blackberry pearl probably burnt out. That is one of the most common issues with a wet phone.
May 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Flip Mino won't turn on!
I had the same problem. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Feb 03, 2009 | Pure Digital Flip Video Ultra Camcorder
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Display will not show when tv flips out!
MOST SCREENS R NOT ON IN THERE RESTING STATE, THERE USUALLY A MECHANISM THAT TURNS THE SCREEN OPEN WHEN IT OPENS, TRY SLIGHTLY PUSHING THE SCREEN BACK LIGHTLY TO SEE IF IT COMES ON HOWEVER IF U CAN RESET IT , TRY THAT IF THAT DOESN,T IT WOULD HAVE TO BE REPAIRED FROM THE MANUFACTURE
Sep 02, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
T-Mobile Sidekick Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
