Question about Dryers
Broken drive belt on Simpson Eziloader 5kg clothes dryer
5 Suggested Answers
SOURCE: Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Posted on Jun 29, 2010
heatman101
  • 43501 Answers
SOURCE: Time not advancing. Position of where timer stops
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer is bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
  • 3074 Answers
SOURCE: simpson 5kg eziloader drier was
check on the motor for a reset button
Posted on Oct 30, 2010
SOURCE: Where does the spring clip
Hi, I too have one of these dryers & have also found a spring, along with alot of fluff, some staples, & remains of the rear seal inside the dryer. must be a manufacturing fault by the looks of things, the spring was bent & twisted & must hold the seal in place. I would say it will need to go to the repair people for replacement. also note the fluff (remains of the seal) had an area where it had burnt from the heating element & could cause a fire.
Posted on Mar 31, 2011
Hi, my 6 month old Simpson 5kg Eziloader dryer blew a fuse today. Have plugged it into a different power plug and now its not working and making a humming noise. Any suggestions?
have a service technician come and look the start/run capacitor for the motor
blowing a fuse then humming indicates a capacitator problem
Jul 07, 2015 | Dryers
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Nov 16, 2014 | Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
Time not advancing. Position of where timer stops changes. It appears to be slipping (Simpson 5kg Eziloader).
The timer is bad...
heatman101
Aug 25, 2010 | Dryers
Jun 21, 2010 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Aug 29, 2009 | Dryers
Dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
108 people viewed this question
Top Dryers Experts
