Question about Omega 1000 Juice Extractor
Serial number in omega 1000 juicer - Omega 1000 Juice Extractor
SOURCE: how to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Posted on Apr 26, 2008
  • 356 Answers
SOURCE: Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Posted on Jun 30, 2009
  • 356 Answers
SOURCE: Vibration
DIFFICULT TO USE. SHOULD HAVE GONE
FOR THE 4000 WHICH EJECTS THE PULP.
SOMETIMES THE BLADE JUMPS UP AND
CUTS THE BOTTOM OF THE CHUTE IN-
CREASING THE GAP BETWEEN THE BLADE
AND CHUTE BOTTOM. INSPECT AND I YOU
NEED A NEW COVER CALL OMEGA AT 717
561 1105.
  • 356 Answers
SOURCE: Latch arm broken on my omega 1000 juicer. I have
Omega can walk you through it, but have a file handy because the new latch
arms are not a perfect fit for the older juicers. You might want to remove the
4 screws on the bottom to separate the base for better access. If you have
a little mechanical ability it can be done, if not it could get tense.
Posted on Feb 02, 2011
  • 356 Answers
SOURCE: My omega 1000 juicer won't
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
Posted on Apr 26, 2011
I have a 15 year old Omega 1000 that needs an arm replacement. Is it possible?
LOOK AT ALL THE OTHER JUICER`s they are not made that difffernt just put another drive on it and run the one that fits it !?
Aug 30, 2011 | Omega 1000 Juice Extractor
My omega 1000 juicer won't turn on - I just bought it today.
a call.
Apr 23, 2011 | Omega 1000 Juice Extractor
I have an Omega Juicer Model 1000. When I try to juice citrul fruit. The jicer may only turn for a second or two than stops. When I push down on the citrus it oftentimes will not operate.
If you're talking about the citrus attachment, there may be a
problem with the gearing inside. I have one for my Acme
which I don't use because of it's awkwardness and juice
splattering characteristics. Better off with an inexpensive
citrus juicer and leave the Omega to its carrots and apples.
Feb 08, 2011 | Omega 1000 Juice Extractor
Latch arm broken on my omega 1000 juicer. I have ordered one. How is it attached?
Aug 26, 2010 | Omega 1000 Juice Extractor
Juicer just stopped working
call or email omega url:omegajuicersdirect.com
Jun 29, 2010 | Omega 1000 Juice Extractor
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
and view of the situation.
May 20, 2010 | Omega 1000 Juice Extractor
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
May 08, 2010 | Omega 1000 Juice Extractor
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
Oct 02, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Vibration
561 1105.
Oct 01, 2008 | Omega 1000 Juice Extractor
Omega 1000 Juice Extractor Logo
358 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
