Question about Echo Garden
Echo tgrimmer wjring
No spark need wiring diagrram
    Sergeant:
  • 316 Answers
Hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Posted on Feb 18, 2012
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
Where is the coil located on a echo handheld pb255 gas blower?echo
just follow the plug wire right to usally under cylinder or near recoil houseing
Aug 17, 2014 | ECHO, Inc. PB-251C Handheld Blower
Clarion cz 500 wiring diagrram
The wiring diagrams are on pages 29 and 30 of the manual available from here.
Jan 16, 2013 | Car Audio & Video
Echo weed eater not getting any spark?
Remove plug and lay plug base against the cylinder or jumper plug base with jumper wire or battery jumper cables to the cylinder and pull starter cord and see if you have spark on plug, you may have to darken room as some sparks are very hard to see in light. If you have no spark would check the ignition switch by removing wire and make sure the wire does not touch metal. If you still have no spark you probably have bad coil that is if this is not a point type ignition system in which case it could be dirty or pitted points. Would always help if you give model no. When asking questions which we could look up type of machine.
Oct 06, 2017 | Echo Garden
Have no spark on my Echo HC-1500 hedge trimmer. Have replaced coil with new but still no spark. Have also by passed kill switch still no spark. What else can I try
Hi, have you tried a new sparkplug? Also did you set the coil to magnet airgap at 8 thou? Also when you say you by passed the kill switch did you do this by leaving the wire off the coil? Because if you did it at the switch end the wire from the coil may be chafed somewhere and earthing the coil. Hope this helps, regards Phil.
Jul 27, 2011 | ECHO, Inc. 20 In. Double Sided Hedge...
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My echo pb-2100 gas blower has no spark and wont start whats anyone has an idea whats the problem
no spark sounds like the coil, but check the connections and any corrossion in the wires
Oct 13, 2010 | ECHO, Inc. PB-251C Handheld Blower
Ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
Nov 29, 2009 | Echo Garden
95 dodge caravan 3.0 no spark
Check your Auto shutdown relay (ADS), if it's bad that will kill the fuel pump and ignition system too. If the fuel pump is bad or a short in the wire the (ADS) will trigger also. See if you could pull any DTC codes from the PCM. http://www.allpar.com/fix/codes.html Good luck and keep me posted, be glad to help.
Jun 09, 2009 | 1995 Dodge Caravan
2002 toyota echo
ignition wire or oil leak at cylinder valve cover to spark plug
Aug 14, 2008 | 2002 Toyota ECHO
Open Questions:
Garden Logo
101 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
