Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
The camera's card blocked
My camera  show a warning that the memory card is blocked but the memory car is OK because it works in another camera and the little bottom of its is not on the block position.
  • ssnlister Apr 12, 2009
    I can look at my photo's, put it will not let me take any more photo's.
    Bought new car, did the same thing.
  • 477 Answers
Problem is the memory card reader pins might be bent. i normally replace the main board to fix this issue. cost can go from 75.00 and up.
Posted on Nov 05, 2008
My camera shows formatt error when i switch on it. the memory card s not getting formatted. oly 2 options r showed format or switch off..... plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz helppppppppppp.. i
You may have to large of a sd card. If it;s larger than 1mb then you may want to try using another that is smaller. See if that helps you out! Good-luck!!
Apr 06, 2012 | Olympus FE-210 7.1 MP Digital Camera w/...
Hi, I have a Samsung NV3 camera, I have installed a new 4 GB memory card but it is showing memory full. Is there and internal memory on the camera that is full that requires deleting? many thanks
I've tried to download a manual for this camera to give you the most accurate answer possible, however after a few minutes of frustration I'm going to answer this sort of "off the top of my head so to speak" My first impression is that the 4GB memory card my be beyond your cameras capabilities but first try this. Have you checked the memory card to make sure it's not locked I'll include a diagram check the small circle for the correct orientation the arrow shows the lock position.
Diagram
Once you have made sure the card is unlocked install the memory card and then format the card. Formatting "programs and new card to work with the camera it has been installed into. Also Formatting should be done after each download of pictures to the computer hard drive. In this case formatting cleanse the old pictures off and programs the card once again to give optimum performance between the camera and memory card. If this still doesn't work then I suspect the 4GB card is to large for the camera "firmware and you will need to update your camera on the Samsung web site to a newer version of firmware. Sounds complicated but heck i did it so it's not all that technical. Also the memory card you are replacing may only need to be formatted to begin to work properly again (that's if you were having problems)
Jan 05, 2011 | Samsung NV3 Digital Camera
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
Placed a new sd-hc card in an Easyshare Z650, camera responds "Memory card requires formating" hit continue twice and formatting will not take place. what are my options?
go to the menu and push (format memory card) then a a warning will come up that says (Warning Formating card will erase all that is on the care) push OK and it should format in might take some time !!Good Luck!!:)
Apr 02, 2010 | Kodak EasyShare Z650 Digital Camera
Will not recognize the PC. USB cable OK. Memory
Use a card reader to download your pics...works every time.
Mar 28, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Takes perfect pictures then shows read error or memory card error & freezes
format the memory card and then try!! if this doesn't work buy a new memory card ...
Sep 26, 2008 | Fuji Cameras
Just bought the camera. I bought 2.0 GB of memory (San Disk)
I'm sorry but it is hard to understand your problem. Did you try to remove the card and see if there is any dirt or something blocking the contacts? Also if the camera will not format the card try pluging the camera into your PC and right click on the icon labled "Removable Disk (E:)" (the "E" may be a different letter) and the click on the Format... option that appears (about halfway down the list that pops up) and click start and click "OK" on the warning that pops up.
**AS THE WARNING STATES YOU WILL LOSE ALL SAVED DATA ON YOUR CARD BY FORMATING IT**
Apr 03, 2008 | Olympus Stylus 790SW Digital Camera
Can not download images
Tell me more about the computer and the operating system
Mar 16, 2008 | Canon PowerShot A520 Digital Camera
Memory card
Make sure you have saved everything you want from the card on your PC, then format the card (FAT 32) with the card in the card-reader.
Then put the card back in the camera.
Can't guarantee this will work, but it's worth a try.
Feb 04, 2008 | Samsung Digimax A402 Digital Camera
Vivicam 5386 copying images to memory card
To copy pictures from memory to your memory card turn your camera on and press the button above the menu button. This will start showing the pictures already on your memory card. Next, press menu and the down arrow. This down arrow is located on the round button with the "OK" in the center. Your choices should be DELETE, SLIDE SHOW, PROTECT, QUALITY CHANGE, RESIZE, and the one that you want,COPY TO CARD. Press OK and the camera will copy pictures from internal memory to the memory card. This information is on page EN-62 and EN-63. I know that this works because I was testing the information as I was typing it!
Oct 02, 2007 | Vivitar ViviCam 5386 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
