Question about Music
Ct-380 casiotone doesn't turn on with batteries or ac adapter
Stopped working
4 Suggested Answers
TekSolution
  • 4 Answers
SOURCE: power adapter specification ct-630
Hi - look in back or under keyboard for power specs.Then go to Guitar Center and the right adapter. GuitarCenter.com has casio power adapters.
Posted on Jan 04, 2010
Testimonial: "Could not match keyboard infor to GC online desc., but found a GC store 5 miles away. They were very helpful. "
app_3rp12521
SOURCE: I need a casiotone ct-370 manual
Try this site. It has most of the old Casio manuals for download. http://generror.wordpress.com/2010/07/04/casio-keyboard-manuals/
Posted on Apr 24, 2012
The Casio CT-630 AC Adapter that came with my system is Model AD-5U and has an output of DC 9.0Volts at 850mA. Hope this helps.
Posted on Jun 27, 2012
Casiotone ct 660
Sounds like it might be mono output. You can get a mono to stereo adapter, but of course you will hear the same in each headphone.
Aug 14, 2014 | Music
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Casiotone ct630
I haven't been able to find documentation to be sure if the CT-630 has MIDI ports on it (my guess is no, but please check). If it does, you can get something like the Yamaha UX16 USB MIDI Interface cable to connect the keyboard to a PC.
If not, sorry, it seems the only thing you could do is record the audio output.
Aug 17, 2013 | Music
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
Feb 26, 2012 | Music
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
Power adapter specification ct-630
Jan 04, 2010 | Music
I have a Casiotone MT70 made in 1984. How do I check the polarity as I need to get an AC Adaptor and don't want to damage the keyboard?
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Oct 07, 2009 | Casio Music
Music Logo
54 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
