Ac plug in for E15T flat screen monitor
I have the monitor but no power cord or maybe its called a/c adaptor plug,it is a emachine monitor model E15Ts
  • 728 Answers
If it has been ripped out of the back of the monitor, then you will need a new monitor. If it has an area in the back of the monitor where you can plug in one end of a power cord, then all you need is to buy you a cord that fits your monitor.
Posted on Oct 22, 2008
I need a Power cord for emachine monitor?
Power cord for monitors are really easy to get the first place I would go to is best buy
Jul 18, 2014 | eMachines E15Ts LCD flat panel monitor...
Cant find where to plug in power cords for emachines monitor screen E15T3r model 568
AC Adapter For eMachines E15T3r 568 LCD Monitor Charger Power Supply...
As you can see from the picture the power plug is a small round connector similar to an audio input. Power Connectors
look for a connector like the DC socket in the picture
Mar 25, 2014 | MPC Computers MPC F1760I 17" FLAT PANEL...
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
My E15T monitor shows the NO SIGNAL message and after that goes dark. I tried it at another computer and it worked at the beggining but after a while also it does the same. it seems like if it is in the...
Check the video cord from the monitor to the computer, if the video cord can detach from both ends, sub the other video cord in place of the other, failing that, the Video Graphics Card is bad or there are motherboard issues.
Jan 03, 2011 | E-Machines e15t 15" Flat Panel LCD Monitor
How to connect emachine flat monitor to my computer?
It sounds as if you are missing the power cord for the monitor. If the cord did not come with your monitor/PC, you can pick one up at any Radio Shack or electronics store. If you could forward me your eMachine model number as well as the monitor model number, I will see if I can better solve this for you without you having to spend anymore money.
Best Regards,
Franklin, C2Solutions
Jul 21, 2009 | E-Machines eMachines Desktop PC
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
A AC adaptor for Aster Flat Screen tv
I have the same problem find this ac power adaptor for my tv, then I have a friend that known where to get this ac adaptor. Maybe you can try it for your self by calling # 323-767-6030.
Thank you.
Jul 30, 2008 | Astar LTV-3201 32 in. LCD Television
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
