Question about NorStar Meridian M7310 Phone
Setting up memory buttons
I just started working for this company and I am not that familiar with this system, but it seems to me that you could program memory buttons for each employee and if you can does this mean they will have a mail box on this phone system?
  • gaylon Oct 22, 2008
    The phone system is the Meridian m7310.
No, you are asking how to program a user speed dial button. That is just a speed dial button, nothing more.
TO don this, and assuming you have an MICS or a CICS:
Press feature *
press the button you want to program
press the extension number of the user you want to see.
done
Posted on Oct 23, 2008
  • Anonymous Nov 19, 2008
    Has this been solved yet?
How do I get a dial tone.can answer the phone.just cannot dial out
I am NOT familiar with YOUR make and model of phone, BUT.... I've had several cordless phone systems over many years, and have had the same problem that you describe. First, here is some background info for you:
The telephone company systems USUALLY have two different dialing systems:
  1. The "old" ROTARY DIALS worked by MECHANICALLY sending out different numbers of electrical pulses which the MECHANICAL "receivers" at the phone company "Central Office" buildings would read and thus connect you to the dialed number.
  2. Some years ago, a "new" dialing system was initiated. That system was called Dual-Tone-Multi-Frequency [or for short, DTMF].
DTMF uses BUTTON KEYS which put out a different electronically generated TONE [related to] for each different NUMBER key pushed, and THAT series of tones told/tells the phone company Central Office receiver computer the number to which you wanted to be connected.
Around the world over the years, most phone companies have, and still use one of these two dialing systems, AND...
Most cordless phone manufacturers designed their phones to work WITH EITHER system, BUT....
The customer IS REQUIRED to "SELECT" which system his phone company uses, while the customer is "SETTING UP" his/her new cordless phone.
THAT process IS INCLUDED in ALL cordless phone set-up instruction packages I've ever seen!!!!!!
Either you need to carefully read and study YOUR installation-set-up instructions and then PROPERLY set your phone's dialing system [to PULSE or DTMF], OR GET SOMEONE who KNOWS WHAT he, or she is doing to do it for you.
I, and I think no one else is able to guide you via back and forth messaging on this site. At least I know I can't because I'm not acquainted with your cordless phone, AND I don't have an instruction/set-up manual to consult!!!!!
Track down your manual, OR search for a replacement manual; the dialer system selection process is NOT DIFFICULT IF you have the manual!!!!!!!
Nov 25, 2014 | Vtech CS6649 - Multi Handset Phone System
Why does blue screen appear suddenly sometimes interrupting my work and all of a sudden the computer restart by itself?
This sounds like a memory problem
try this: goto control panel, system, advanced, performance, advanced, virtual memory, settings
set start size and max size to same
mine is set at 2500
Apr 20, 2011 | Microsoft Computers & Internet
Need to speed up web browser
Type MSCONFIG in Start > Run
Disable most of the Startup items and reboot your PC.
Use Mozilla Firefox for browsing its better.
Jan 05, 2010 | Dell Dimension 3000 PC Desktop
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Nov 02, 2009 | Sanyo DC-DA1000 CD Shelf System
Hello , HP Proliant Server Problem.
Use a different monitor and connect it directly to the server, if problem persist you have a problem with the systemboard or microprocessor.
Jun 29, 2009 | HP ProLiant DL380 G4 36 GB Network Storage...
Cannot set clock or timer
turn the system off and press the clock button on the remote after the clock illuminates hold the memory button on the remote until the hour starts to blink then press the preset up or down to change ( go through 12 hours to change AM PM) then press memory to get to the minutes after setting the minutes press memory to save
Mar 11, 2009 | Sharp XL-1700 CD Shelf System
Songs in my mp3 player?
There are several ways to check the memory - Go to system Settings --> About is one way. If it looks like it is more full than WMP is showing than reformat the player, b/c you have a corrupt database.
System Setting Options
Sleep
: Turns off power automatically after the preset time. Select either <Off>,
<15min>, <30min>, <60min>, <90min>, or <120min>.
Start Mode : You can set the start screen displayed when you turn on the
player. Select from <Main Menu> and <Last State>. Select <Main Menu> to
start the system with the main menu screen while <Last State> will use the last
used menu screen.
Auto Power Off : Automatically turns power off when there is no button
operation after the preset time in the pause mode. Select either <15sec>,
<30sec>, <1min>, <3min>, <5min> or <Always On>.
Default Set : Returns all settings to the default value. Select either <Yes> or
<No>. <Yes> initializes all settings to default. <No> cancels default settings.
Format : Formats the internal memory. Select either <Yes> or <No>.
Selecting <Yes> will format the internal memory and delete all fi les on the
player. Selecting <No> does not format the internal memory. Check before
formatting it.
About : Checks the fi rmware version and memory capacity.
<Firmware Version> displays the current fi rmware version.
<Used> indicates the usage, <Available> indicates the remaining capacity and
<Total> indicates the total memory capacity.
-Tha Mp3 Doctor
May 23, 2008 | Samsung YP-T10 Digital Media Player
Upgraded all hardware, installed all drivers, go to play a game that should work fine but system can't seem to handle it. screen starts to shutter. changed all settings to lowest so that it should provide...
Offhand, what I would suggest is to tweak your OS for maximum performance (not necessarily faster but more efficient and stable). Things you can try are:
1. right click on "My Computer", click on "Properties";
2. click on "Advanced" tab, click on "Performance Settings' button, in "Visual Effects" tab, tick "Adjust for best performance", Apply;
3. in "Advanced" tab, tick both instances of "Programs", Apply;
4. click "Virtual memory" "Change" button, tick "Custom size" type in 2048 or whatever it is that is twice of your memory on both Initial and Maximum, click on "Set" button, OK. OK;
5. Goto Start, Run, next small window type "msconfig" less the quotes, OK;
6. in the "System Configuration Utility" window, "Startup" tab, un-check everything (except perhaps your anti-virus), Apply, OK;
7. Reboot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Not recognizing USB Memory Card
check the BIOS settings to turn on USB ports.
Oct 10, 2007 | ASUS P4P800 SE (890552603657) Motherboard
NorStar Meridian M7310 Phone Logo
127 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
