Question about Garden
Hydraulic fluid overheating in john deere skidder
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
mattofilms
  • 110 Answers
SOURCE: I just purchased a 2440 john deere tractor it was
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Posted on Jul 02, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
Torque spec on 640D john deere skidder
You just go to the link I attached I'm sure you will get the solution of your problem.
Mar 11, 2017 | John Deere Garden
My 2007 648h John Deere skidder makes a loud noise over 2000rpm as though its low on hydraulic oil which it isnt all functions work fine , any ideas
May be sucking air . Check all hoses and clamps between hydraulic tank and pump. Some models had a suction screen in hydraulic tank that when partially plugged will starve pump for oil.
Feb 18, 2017 | John Deere Garden
Where do I add hydraulic fluid to a John Deere 310 B backhoe
There are several places for checking and adding fluid. What seems low, the bucket hydraulics, or the drive hydraulics (ie: tranaxle)
Jul 09, 2016 | John Deere Garden
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
What would cause my hydraulics to keep heating up on a 648g3 skidder?
Friction is usually the cause of hydraulic overheating. Every time the hydraulic oil moves through the system the moving of the hydraulic fluid against the hoses,pumps, cylinders , etc. creates friction. Any restrictions such as valves or filters can be hot spots because of the friction created as the passages get smaller the fluid moves faster creating more friction. Friction = Heat.
I would check the filters to make sure they are clean. Check the valves to make sure they are opening fully. Check hoses for any kinks or pinched spots.Try to operate the skidder at the lowest r.p.m. need for the work being done. Over revving can also cause heat buildup.
Hope this helps.
Bob
Dec 16, 2014 | Cars & Trucks
John Deere 310G that the hydraulics quit working
John Deere 310G
May 29, 2017 | John Deere Garden
Hydraulic system overheating
check all hydraulic filters and check hydraulic valves. Filters is maybe not good or old, hydraulic valves is damaged or soiled. If your model hawe oil cooler check is it clean out and in!
Apr 04, 2011 | John Ertl 132 John Deere 648g Log Skidder
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
