Question about Garden
Husqvarna 122ld manual
How to load twin line on husqvarna lawn trimmer
  • 18 Answers
SOURCE: line trimmer
to much oil in gas or your piston rings are wore and cannot seal the oil or compression.. or adjust your idle screws
Posted on Oct 12, 2008
#1 Taper
  • 1041 Answers
SOURCE: adding trimmer line to spool on husqvarna trimmer-two strings
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
Tunneler
  • 27 Answers
SOURCE: I LOST THE MANUAL TO HUSQVARNA 128L TRIMMER HOW
Here's the link to the manual: Husqvarna 128l Manual
Posted on Aug 24, 2009
#1 Taper
  • 1041 Answers
SOURCE: Husqvarna 323L Line Trimmer - Runs for about 5-10 seconds,
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to seedaylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 26, 2009
  • 203 Answers
SOURCE: No Spark - Husqvarna 125R Trimmer
Check the wire that goes to the "OFF" button. See if it is by chance loose or cracked allowing a short. Beyond that, it would probably be the coil, but I would lean towards some type of a short, especially if you know the plug is OK.
Posted on Jan 10, 2010
Replacing the Coil on a Husqvarna 128CD
I'll send you a link to the 'illustrated parts manual'. pretty straight forward, just unscrews to remove. timing gap should be 0.25 filer guage.
Aug 18, 2012 | Husqvarna 128CD 28cc Gas Line Lawn Trimmer...
Replace string on 323L tap out line terimmer
I'll send you a link to the online manual.
Mar 22, 2012 | Husqvarna 28cc Gas Line Trimmer
What Diameter is the husqvarna 123l fuel line?
In one of the very last pages in your instruction manual (Trimmy VII) it shows a diagram with the string size 2mm or .080". Here is your manual in case you need it. There are some good carburetor adjustment instructions in it. Read carefullyl
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2003/HOUS2003_1140223-95.pdf
Apr 07, 2011 | Husqvarna 28cc Gas Line Trimmer
Unsure on correct way to reload spool with line
Go to smalleng.com they might have a video on how to do, what you need. Check it out awesome website!
Jan 27, 2010 | Husqvarna 28cc Gas Line Trimmer
I need a owner user operating instruction manual for husqvarna gas trimmer model 128LD
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_545196750.pdf
here is a link to the pdf file to huskies website hope this helps, you can print off some or all of the owners manual free of charge.
Nov 04, 2009 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
