Question about HP OfficeJet 7410 All-In-One InkJet Printer
Paper jam there's a paper jam and i can't find a lever to lift to ease it out - any thoughts? thx
  • lynette 8 Oct 24, 2008
    I neglected to say that the jam is in the auto doc feed on top of machine. manual says to pull off the front oanel to gain access. it feels as if it will break if we do. is there any other way to gain access to the top roller area wherehalf page of unseen paper is still wedged?
    thx
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
???? where is it????
Assuming it's in the paper pick-up,remove trays and see if youcan get it there, also look in the back of the machine most of them have a section that comes out, there should be a big knob that you turn and unlocks the door, remove it and you can see the big wheels and hopefully get it from there.
Posted on Oct 23, 2008
  • CheckitRight
    CheckitRight Oct 24, 2008
    If you've torn the paper and only half is left inside the machine then,
    1-there should be a door on the Doc feeder that you can open, this is probably what they are referring to, grab a hold of the plastic that is near the rollers and lift up.
    2- lift the doc feeder up and look in the front and up this is where the document is supposed to pass trough to make the copy and it feeds back in to deliver it on th the top.
    Let me explain the process a little more. When you put the paper in the doc to make a copy it actually makes it on the SMALL strip of glass not on the big one. so it passes trough and only a 3/4 inch is read and copied.
    while if you put in on hte glass is scans the whole paper.
    Hope this helps, good luck!
Cannon pixma mx922 paper jam
I had a very bad jam (paper tore...you know the drill...see upper panel). My wife and I used a chopstick and hemostats to gently, gently lift the rollers and ease the paper out (lower panel...most of the paper has been pulled out). The stick should be applied to the support between the rollers. You have to go from roller-pair to roller-pair, easing the paper out without ripping it.
Oct 14, 2013 | Canon Office Equipment & Supplies
Show paper jam without actual paper jam hp laserjet p2055
1.check the back cover is open and the green levers are down.
2.open the front cover remove the cartridge ,you can see a green lever ,just lift it up and see any paper pieces are there.
Aug 05, 2011 | HP P2055DN LaserJet Monochrome Printer
How do I fix a paper jam cef for epson aculaser cxn11nf?
Diagram of doors should be above control panel of printer.
Lift ADF/Scanner up. Open door "C" just below it. Lift orange photoconductor lever up to release photoconductor. Lift photo conductor up towards you. Inspect for jammed paper and remove if necessary. Replace photoconductor, close lever and door "C".
Open door "E" on rear of printer and look for jammed paper and remove. Close door "E".
Last place to look is in paper tray. Take stack of paper out and look for paper jam. Removed as needed.
These are the three places i have had jams and you will only find the jam in one of them. Most likely it will be in back in Door E
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Jun 24, 2009 | HP LaserJet 3600n Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
INTELLIFAX 2820--PAPER/SCANNER JAM
go to brother & download driver for printer. good luck !
Jul 13, 2008 | Brother IntelliFax-2820 Laser Fax
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
